Sorry my fault. It has to be:
feature:install openhab-binding-weather1
Maybe you also have to change the log:set commands, too, by adding a 1 at the end.
I ran the command and now I can see it is shown in the bindings but nothing in the logs and still the same problem. Nothing is appearing in the sitemap and widget.
Did you restart Openhab?
Yes many times with sudo reboot command.
And I can now see that the darksky is showing 6 API calls today. So that looks bit ok but not sure why the data is not getting displayed even now.
Could you please post your sitemap configuration here?
This is not so.
Yes, this is true. But I copied this from official documentstion. See here:
You’re referring to this?
Note that the log levels set using the log:set commands are persistent and will be applied upon restart.
I agree it’s poorly worded. It should just say the changes are saved automatically or that they’ll survive a restart…
Yes, correct. I missunderstood this. Sorry.
Here’s the sitemap
sitemap home label=“My home automation” {
Frame label=“Date” {
Text item=Date
Frame label=“Weather in Lombard” {
Text item=Temperature icon=“Temperature” valuecolor=[>25=“red”,>15=“green”,>5=“orange”,<5=“blue”] label=“Temperature [%.2f °C]”
Text item=Humidity icon=“rain”
Text item=Pressure icon=“sun_clouds”
//Webview url="/weather?locationId=home&layout=example&iconset=colorful" height=7
Frame label=“Demo” {
Switch item=Lights icon=“light”
Text item=LR_Temperature label=“Livingroom [%.1f °C]”
Group item=Heating
Text item=LR_Multimedia_Summary label=“Multimedia [%s]” icon=“video” {
Selection item=LR_TV_Channel mappings=[0=“off”, 1=“DasErste”, 2=“BBC One”, 3=“Cartoon Network”]
Slider item=LR_TV_Volume
Frame label=“Hue”{
// Bulb1
Switch item= Light1_Toggle
Slider item= Light1_Dimmer
Colorpicker item= Light1_Color
Slider item= Light1_ColorTemp
Switch item= Light1_Alert mappings=[NONE=“None”, SELECT=“Alert”, LSELECT=“Long Alert”]
Switch item= Light1_Effect
// Bulb2
Switch item= Light2_Toggle
Slider item= Light2_Dimmer
Slider item= Light2_ColorTemp
and here’s the Items.
Number Temperature “Temperature [%.2f °C]” {weather=“locationId=home, type=temperature, property=current”}
Number Humidity “Humidity [%d %%]” {weather=“locationId=home, type=atmosphere, property=humidity”}
// atmosphere
Number Visibility “Visibility [%.2f km]” {weather=“locationId=home, type=atmosphere, property=visibility”}
Number Visibility_Mph “Visibility [%.2f mi]” {weather=“locationId=home, type=atmosphere, property=visibility, unit=mph”}
Number Pressure “Pressure [%.2f mb]” {weather=“locationId=home, type=atmosphere, property=pressure”}
Number Pressure_Inches “Pressure [%.2f in]” {weather=“locationId=home, type=atmosphere, property=pressure, unit=inches”}
String Pressure_Trend “Pressuretrend [%s]” {weather=“locationId=home, type=atmosphere, property=pressureTrend”}
Number Ozone “Ozone [%d ppm]” {weather=“locationId=home, type=atmosphere, property=ozone”}
Number UV_Index “UV Index” {weather=“locationId=home, type=atmosphere, property=uvIndex, scale=0”}
please use code fences next time!!
I put all into it, now it’s readable:
.sitemap
Text item=Date
Group item=Heating
Frame label=“Hue”{
// Bulb1
// Bulb2
.items:
// atmosphere
Are you sure that all was running before you ONLY changed services\weather.cfg from yahoo to ForecastIo?
in .items file this entry is doubled:
@Celaeno1 Thanks for providing the updated code. Even though after all of this the issue is still the same and yesterday the system did made some API calls and even after that there.
Also previously the Yahoo Weather was working fine for about an year.
Please do the following:
log:set TRACE org.openhab.binding.weather
Restart OH Service, watch the karaf console log:tail
for any messages regarding weather.
Could you also please check this file: weather.config
/var/lib/openhab2/config/org/openhab/weather.config
@Celaeno1 Thanks, I was able to get some logs and here are some of the entries.
2019-01-09 01:27:39.281 [DEBUG] [org.openhab.binding.weather ] - BundleEvent STOPPING - org.openhab.binding.weather
2019-01-09 01:27:39.291 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent UNREGISTERING - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={service.id=455, service.bundleid=331, service.scope=bundle, event.topics=openhab/command/*, service.pid=org.openhab.weather, component.name=org.openhab.binding.weather, component.id=309} - org.openhab.binding.weather
2019-01-09 01:27:39.305 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent UNREGISTERING - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.weather.WeatherBindingProvider}={service.id=454, service.bundleid=331, service.scope=bundle, component.name=org.openhab.binding.weather.genericbindingprovider, component.id=310} - org.openhab.binding.weather
2019-01-09 01:27:39.336 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent UNREGISTERING - {javax.servlet.ServletContext}={osgi.web.version=1.13.0, osgi.web.contextpath=/, service.id=458, osgi.web.symbolicname=org.openhab.binding.weather, service.bundleid=331, service.scope=singleton, osgi.web.contextname=custom} - org.openhab.binding.weather
2019-01-09 01:27:39.341 [DEBUG] [eather.internal.bus.WeatherActivator] - Weather binding has been stopped.
2019-01-09 01:27:39.346 [DEBUG] [org.openhab.binding.weather ] - BundleEvent STOPPED - org.openhab.binding.weather
Also got a few more
2019-01-09 01:28:28.883 [TRACE] [er.internal.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=localObsDateTime,target=condition.observationTime,converter=UTC_DATE]
2019-01-09 01:28:28.898 [TRACE] [er.internal.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=date,target=condition.observationTime,converter=DATE]
2019-01-09 01:28:28.906 [TRACE] [er.internal.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=lastBuildDate,target=condition.observationTime,converter=FULL_UTC_DATE]
2019-01-09 01:28:28.921 [TRACE] [er.internal.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=forecast.date,target=condition.observationTime,converter=SIMPLE_DATE]
2019-01-09 01:28:28.933 [TRACE] [er.internal.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=ob.timestamp,target=condition.observationTime,converter=UNIX_DATE]
2019-01-09 01:28:28.938 [TRACE] [er.internal.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=periods.timestamp,target=condition.observationTime,converter=UNIX_DATE]
2019-01-09 01:28:28.944 [TRACE] [er.internal.metadata.MetadataHandler] - Added provider mapping METEOBLUE: ProviderMappingInfo[source=last_model_update,target=condition.observationTime,converter=JSON_DATE]
2019-01-09 01:28:28.951 [TRACE] [er.internal.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=weather.id,target=condition.id,converter=STRING]
A few more:
2019-01-09 01:28:30.271 [WARN ] [eather.internal.common.WeatherConfig] - Parameter ‘location..latitude’ empty or in wrong format (‘XXXXXXXX’). Check openhab.cfg.
This looks important. Yahoo didn’t use lat/long, it used “woeid”. But other services will want lat/long.
So youve got those - that should be in weather.cfg of course, and not the “old style” openhab.cfg the error message hints at.
Have a look and see if you have a cached weather.config version, and if so just stop OH, delete that (keeping weather.cfg) and reboot.
First of all. Your weather1 binding seems to be stopped. Please check again, if it is installed.
But maybe it is only an old entry from Shutdown OH Service!
Second, if the binding is not installed:
Check $OPENHAB_CONF/services/addons.cfg if there is the following:
binding = weather1
Then check your weather.cfg again.
Longitude and Latitude
Format: xx.xxxx
Then remove the doubled entry from your .items file:
And ONCE AGAIN check the entries of
THIS IS A DIFFERENT FILE!!! or at least delete the file and restart OH
@Celaeno1 Thanks a lot for your help and bearing with me. I even had a look at the other file and it didn’t work then I decided to reinstall and I took the backup of important config files and did a fresh installation and now everything works like a charm. Still in the process of fixing the original weather template but so far here’s how it is looking like.
I’m already using the nice HTML webview for a long time in OH1 and OH2. Is there a way to use this also in OH 3 (with the Openweather binding)?
Thanks for your feedback !
