Hi
I try to run my new xiaomi grateway and aqara door sensor but after 2 hours of fighting I think it is just too much for me. Can anyone help me with this one? I have no idea what is wrong. What I have done so far:
- on my mi home mobile app I added gateway and sensor. I enabled communication and got password.
- I installed Xiaomi Mi Smart Home Binding on my OH2
- Xiaomi Gateway has been found so I added it. As soon as I added it 1 more thing has been found - Xiaomi Mi Smart Home Gateway (I don’t know why 2 devices are found)
- I updated Xiaomi Gateway and typed password from developer mode in mobile app.
- Thing is added in Control pane but any sliders etc wont affect on a gateway - I am not able to change light for instance.
My goal is to add door sensor which is visible and it is working fine in mobile app but OH2 doesn’t see it - through binging, none things has been found.
I checked logs and there are some exceptions
2018-12-08 20:55:23.709 [ERROR] [org.openhab.binding.mihome ] - FrameworkEvent ERROR - org.openhab.binding.mihome
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mihome [206]
Another singleton bundle selected: osgi.identity; type=“osgi.bundle”; version:Version=“2.1.0.201704221211”; osgi.identity=“org.openhab.binding.mihome”; singleton:=“true”
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-12-08 20:55:24.060 [ERROR] [discovery.XiaomiItemDiscoveryService] - Unknown discovered model: sensor_magnet.aq2
2018-12-08 20:55:28.752 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/ttyACM0’
2018-12-08 20:55:28.780 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-12-08 20:55:28.798 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-12-08 20:55:28.836 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-12-08 20:55:28.839 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-12-08 20:55:32.136 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-12-08 20:55:32.140 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2018-12-08 20:55:32.142 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 3: Node found
2018-12-08 20:55:32.145 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-12-08 20:55:32.147 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-12-08 20:55:32.150 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-12-08 20:55:32.152 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 3
2018-12-08 20:55:32.154 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
Does anyone know what is going on and what I am doing wrong here?
