havaak
(User1389239239)
January 4, 2019, 1:06pm
1
As of today there is no temperature from Yahoo anymore in my UI. When checking the log:
2019-01-04 13:51:04.177 [WARN ] [al.connection.YahooWeatherConnection] - Communication error occurred while getting Yahoo weather information: java.util.concurrent.ExecutionException: java.net.UnknownHostException: query.yahooapis.com: No address associated with hostname
2019-01-04 13:56:04.205 [WARN ] [al.connection.YahooWeatherConnection] - Communication error occurred while getting Yahoo weather information: java.util.concurrent.ExecutionException: java.net.UnknownHostException: query.yahooapis.com: No address associated with hostname
Found this on the yahoo website:
Important EOL Notice: As of Thursday, Jan. 3, 2019, the weather.yahooapis.com and query.yahooapis.com for Yahoo Weather API will be retired.
To continue using our free Yahoo Weather APIs, use https://weather-ydn-yql.media.yahoo.com/forecastrss . Contact yahoo-weather-ydn-api@oath.com for credentials to onboard to this free Yahoo Weather API service.
What to do next?
kr
Han
RolfV
(Rolf Vermeer)
January 4, 2019, 1:19pm
2
Indeed, and the binding will be removed as well for that exact reason:
master ← 9037568:yahoo
opened 03:12PM - 11 Nov 18 UTC
In accordance with [Smarthome issue #6491](https://github.com/eclipse/smarthome/… issues/6491)
So for example switch to Open Weather Map:
By the way, also see this topic:
havaak
(User1389239239)
January 4, 2019, 1:20pm
3
Cheers, will do! And I see that my search of the forum did not reveal that topic
metin
(Metin)
January 4, 2019, 4:19pm
4
I can’t see the binding. However, I haven’t upgraded to openHAB 2.4 yet – does it require 2.4?
PtrO
(PeterO)
January 5, 2019, 12:47am
5
Have the same… since 03jan19 21u51…
Why why why are these so called friendly services doing this.
The moment you start using some reliable service, its almost guaranteed it will be changed or stopped.. Very annoying.
Samuel_B
(Samuel)
January 5, 2019, 10:01am
6
Thanks Rolf for the workaround. Works fine for me (took me one hour to set up though).
Gad_Ofir
(Gad Ofir)
January 5, 2019, 11:00pm
7
same here cant find the bidning do i need 2.4?
havaak
(User1389239239)
January 5, 2019, 11:32pm
8
yes, binding is only available for 2.4, which got me in a new situation…
Gad_Ofir
(Gad Ofir)
January 6, 2019, 6:56am
9
i have 2 OH installed on widnows , but now both on 2.4
thaks Yhaoo for making do this brave step
metin
(Metin)
January 6, 2019, 2:11pm
10
If you are still on 2.3, and cannot or do not want to upgrade to 2.4 yet, you may use the Weather binding with Open Weather Map.
Edit:
It works, yet logs errors .
