I just went ahead and deleted the thing using HABmin, then deleted the XML file, then re-added it. I e-mailed you the log snippet for that activity.
The log is very short and doesn’t really have anything useful - it doesn’t have the device initialisation at all. It shows the inclusion of node 17, but no initialisation.
In HABmin, if you select the thing, then in the top right corner there’s a menu. In this menu should be an option “Reinitialise device” (or something similar). You might need to also enable “Advanced mode” which is also an option in the same menu.
This option is only shown if the device has completed initialisation, but I think this was the case from the previous logs so there shouldn’t be any issue.
Thank you for helping me find the reinitialize option. The log looks a little more interesting this time. E-mailed.
Thanks. The issue seems to be a problem with the database export - I’ll take a look tonight.
I’ve tested with commit f93bcb and it seems to work, and fairly quickly. Though, this did seem to be something that would resolve itself with enough up-time. I’ll report back if I see it again.
