I recently acquired a Silicon Labs / ACC-UZB3-U-STA Z-wave stick and plan to try out Z-wave as an alternative to the wifi connected devices I am currently using with OpenHAB 3.0.1 on a Pi4B running OpenHABian 2.5.11-1.
After installing the stick and the binding, I added the bridge Thing manually using the UI. OpenHAB shows that it the bridge Thing is OFFLINE.
I don’t yet have any Z-wave devices to connect to the network. The first one is arriving later this week.
My question is whether the OFFLINE means there is something wrong with my installation of the stick, or it it just telling me that since I don’t have any Z-wave devices yet, that the bridge has nothing to connect to.
If the former, any suggestions for troubleshoot?
Here is the log following an activation of the Thing.
2021-06-06 19:23:06.688 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Creating ZWave discovery service for zwave:serial_zstick:d55bff6cef with scan time of 60
2021-06-06 19:23:06.690 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Active zwave:serial_zstick:d55bff6cef
2021-06-06 19:23:06.691 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2021-06-06 19:23:06.726 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2021-06-06 19:23:06.727 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller zwave:serial_zstick:d55bff6cef.
2021-06-06 19:23:06.719 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:d55bff6cef' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2021-06-06 19:23:06.728 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:d55bff6cef' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2021-06-06 19:23:11.730 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyAMA0'
2021-06-06 19:23:11.738 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Starting receive thread
2021-06-06 19:23:11.740 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2021-06-06 19:23:11.740 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Starting ZWave thread: Receive
2021-06-06 19:23:11.741 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initialising ZWave controller
2021-06-06 19:23:11.743 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2021-06-06 19:23:11.743 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-06-06 19:23:11.744 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-06-06 19:23:11.744 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2021-06-06 19:23:11.746 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2021-06-06 19:23:11.749 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2021-06-06 19:23:11.750 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Scheduling network mesh heal for 7 hours time.
2021-06-06 19:23:14.746 [DEBUG] [.ZWaveController$InitializeDelayTask] - Initialising network
2021-06-06 19:23:14.751 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 19 to queue - size 1
2021-06-06 19:23:14.752 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-06-06 19:23:14.753 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 15 E9
2021-06-06 19:23:14.754 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2021-06-06 19:23:14.784 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-06-06 19:23:14.785 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 19: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-06-06 19:23:14.786 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 20 to queue - size 1
2021-06-06 19:23:14.787 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-06-06 19:23:14.787 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 21 to queue - size 2
2021-06-06 19:23:14.788 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-06-06 19:23:14.789 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 22 to queue - size 3
2021-06-06 19:23:14.789 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-06-06 19:23:14.790 [DEBUG] [rialmessage.GetSucNodeIdMessageClass] - Get SUC NodeID
2021-06-06 19:23:14.791 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 23 to queue - size 4
2021-06-06 19:23:14.791 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-06-06 19:23:16.786 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 19: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2021-06-06 19:23:16.787 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 19: Transaction is current transaction, so clearing!!!!!
2021-06-06 19:23:16.788 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 19: Transaction CANCELLED
2021-06-06 19:23:16.789 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:19 CANCELLED
2021-06-06 19:23:16.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-06-06 19:23:16.800 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 20 DC
2021-06-06 19:23:16.801 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2021-06-06 19:23:16.824 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-06-06 19:23:16.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 20: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-06-06 19:23:18.825 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 20: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2021-06-06 19:23:18.826 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 20: Transaction is current transaction, so clearing!!!!!
2021-06-06 19:23:18.826 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 20: Transaction CANCELLED
2021-06-06 19:23:18.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:20 CANCELLED
2021-06-06 19:23:18.828 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-06-06 19:23:18.832 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 07 FB
2021-06-06 19:23:18.833 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2021-06-06 19:23:18.854 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-06-06 19:23:18.855 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 21: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-06-06 19:23:20.855 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 21: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2021-06-06 19:23:20.855 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 21: Transaction is current transaction, so clearing!!!!!
2021-06-06 19:23:20.856 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 21: Transaction CANCELLED
2021-06-06 19:23:20.856 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:21 CANCELLED
2021-06-06 19:23:20.857 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-06-06 19:23:20.859 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 06 96 0F 65
2021-06-06 19:23:20.860 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 06 96 0F 65
2021-06-06 19:23:20.894 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-06-06 19:23:20.896 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 22: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-06-06 19:23:22.896 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 22: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2021-06-06 19:23:22.897 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 22: Transaction is current transaction, so clearing!!!!!
2021-06-06 19:23:22.897 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 22: Transaction CANCELLED
2021-06-06 19:23:22.898 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:22 CANCELLED
2021-06-06 19:23:22.899 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-06-06 19:23:22.904 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 56 AA
2021-06-06 19:23:22.905 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 56 AA
2021-06-06 19:23:22.934 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-06-06 19:23:22.935 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 23: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2021-06-06 19:23:24.936 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 23: Timeout at state WAIT_RESPONSE. 3 retries remaining.
2021-06-06 19:23:24.937 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 23: Transaction is current transaction, so clearing!!!!!
2021-06-06 19:23:24.937 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 23: Transaction CANCELLED
2021-06-06 19:23:24.938 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:23 CANCELLED
2021-06-06 19:23:24.939 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
