[SOLVED] Z-Wave unreliable in 2.5.0.M4
I thought I’d try this program as well, seems like a good tool for managing z-wave. I fail on the first step however. The one where I should select which port my Z-stick is in. The list is simply empty. Tried putting the stick in different USB ports, clicking the detect and refresh buttons etc, just nothing. Anyone knows what to do? Do I need to install any special drivers? It’s a Aeotec Z-stick S2.
edit: Ha! Found them! After a looong time of looking. For anyone else looking: https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
Dumb question… can someone paste a link to this tool on the silicon labs website? I’ve downloaded a few different tools but can’t seem to find this windows utility
TIA!
Dave
@dbadia
You can find a link in this topic. (above the first picture!)
EDIT: If you want to download it directly from Silabs, then use this manual.
The latest version of Z-Wave PC Controller is 5.39 !
Thanks for adding that link @Celaeno1
@dbadia another and longer guide is here https://forum.fibaro.com/topic/29923-tutorial-z-wave-diagnostics-with-pc-controller-and-zniffer/
This is getting good :slight_smile:
I ran the network heal, but I didn’t see a map like this. From what I can tell in the log, it looks like the heal completed successfully.
Unrelated… when I tried to do an NVMbackup, I got this error
Anyone else get this error? I wondering if my stick (Aeotec Gen5 ZW090-A) is on the fritz…
The good old Aeotec. The slight odd boy among z-wave plus.
It is an older SDK and they may well not have implemented all of the options. I think Aeotec have their own utility but not definite. Someone may chip in but it may also be worth talking to them and seeing if they have a firmware that does or their own tool.
That mao is on a different tab and you need to press the reload button. This button calls the API and the controller passes the current topology to the PC Controller Program. On first visit it will be blank.
Aeotec has a backup utility. See this Link: https://aeotec.freshdesk.com/support/solutions/articles/6000108806-z-stick-gen5-backup-software.
Aeotec use an old firmware and don’t (as far as I know) have anything newer (at least last time I spoke to them about this which was a few months back now, but at that point they had no plans to update it).
Thanks, I think I’ve actually used that in the past. Probably time for me to run another backup
With links hidden for “members only” :frowning:
Typical Fibaro. I finally lost it with them when they changed so you could not have root access other than by break.
but also they were getting so many chinese bots and also warranted and unwarranted criticism.
We do need something on this end. I will add it to my lists of things to cover. I am sure Thomas will give me permission to do a bit of cut and paste.
Does the UZB stick work with the zsniffer?
UZB3 is very well tested as a zniffer and flashes without issue. It is the same hardware (other than the colour of case) as the official zniffer that comes with the dev kit.
digikey or mouser sell but make sure if you are a
US user you buy one with -U in the product code
Ia european user you want -E inthe product code
etc etc
They will work across areas as the SAW filter only removes about 40% of signal strength between E and U but it is daft to suffer shorter reception. As they do not transmit you would not break any local regs if you used a zniffer of the wrong area in desperation.
FYI https://z-wave.me/webinar-z-wave-network-diagnostics-with-z-way-controller/
