Recently I did some testing with RFC2217 and it is possible to get it working with bindings. ![]()
The issue isn’t that there is no discovery implementation in the RFC2217PortProvider. The issue is that the ZWave binding has a workaround which results in that only discovered ports can be used. I’ve created issue #1332 for that.
Another issue is that some methods throw exceptions when used with a RFC2217 port.
It also helps to not limit serial port options in UIs so users can enter RFC2217 port details.
I made some changes for all of that in this commit.
Since I don’t have a ZWave controller, maybe someone can help testing if these changes make it possible to use RFC2217 connections with ZWave by testing this org.openhab.binding.zwave-2.5.5-SNAPSHOT.jar?
