Solving slow HabPanel
Hi All
I need to solve why this is so slow, its absolutely killing my whole system. Its unusable slow.
Its slow on my gigabit/10gbit lan with Ubiqiti wifi, its slow via 4G.
BasicUI is just fine. Doesnt matter what browser or what device I use, they are all slow. OH2 is sitting at about 5% CPU and runs on a Xeon processor with Hardware raid and SAS disks so it’s not the hardware.
Is anyone able to help me pinpoint the issue? It’s so bad, I can barely even change dashboards in HabPanel :frowning: :frowning: :frowning:
Thank you
When did it start?
Did you make recent modifications to the panel?
Do you have a back-up of the HABpanel json?
Also try this to verify your items requests isn’t taking too long for some reason, this would explain the delay when switching dashboards:
Hi Vincent, its been fairly slow for as long as I can recall (I’ve made some posts in the past) but now its just terrible.
I’ve added a few items to existing dashboards.
@ysc , OK I shall.
Had a look at this, 167 errors in Chrome (i use firefox generally)
https://code.angularjs.org/1.5.11/docs/error/$rootScope/infdig?p0=10&p1=%5B%5B%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A392%2C%22oldVal%22%3A391%7D%2C%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A392%2C%22oldVal%22%3A391%7D%5D%2C%5B%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A393%2C%22oldVal%22%3A392%7D%2C%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A393%2C%22oldVal%22%3A392%7D%5D%2C%5B%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A394%2C%22oldVal%22%3A393%7D%2C%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A394%2C%22oldVal%22%3A393%7D%5D%2C%5B%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A395%2C%22oldVal%22%3A394%7D%2C%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A395%2C%22oldVal%22%3A394%7D%5D%2C%5B%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A396%2C%22oldVal%22%3A395%7D%2C%7B%22msg%22%3A%22fn%3A%20function%28c%2Ce%2Cf%2Cg%29%7Bf%3Dd%26%26g%3Fg%5B0%5D%3Aa%28c%2Ce%2Cf%2Cg%29%3Breturn%20b%28f%2Cc%2Ce%29%7D%22%2C%22newVal%22%3A396%2C%22oldVal%22%3A395%7D%5D%5D
And
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=utf-8"/>
<title>Error 404 Not Found</title>
</head>
<body><h2>HTTP ERROR 404</h2>
<p>Problem accessing /habpanel/UNDEF. Reason:
<pre>    Not Found</pre></p><hr><a href="http://eclipse.org/jetty">Powered by Jetty:// 9.3.21.v20170918</a><hr/>
</body>
</html>
Some screenshots. Items taking 7 seconds? is that how I read that?
Here is my OH2 server CPU load
top - 07:33:35 up 1 day, 10:49,  2 users,  load average: 0.33, 0.38, 0.36
Tasks: 209 total,   1 running, 138 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.2 us,  1.0 sy,  0.0 ni, 95.9 id,  1.9 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem : 16371408 total, 12248372 free,  1967200 used,  2155836 buff/cache
KiB Swap:  4194300 total,  4194300 free,        0 used. 14068076 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
 1946 root      20   0  154708  31452   8916 S   3.1  0.2  32:42.11 python
 1949 root      20   0  154712  31320   8888 S   3.1  0.2  32:18.38 python
 1957 root      20   0  154712  31220   8792 S   3.1  0.2  32:01.06 python
13116 kris      20   0   42884   4032   3320 R   3.1  0.0   0:00.18 top
14120 openhab   20   0  9.773g 863080  20944 S   3.1  5.3  68:56.88 java
 1943 root      20   0  154708  31244   8820 S   1.5  0.2  32:33.59 python
    1 root      20   0  225664   9552   6784 S   0.0  0.1   0:13.32 systemd
    2 root      20   0       0      0      0 S   0.0  0.0   0:00.04 kthreadd
    4 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 kworker/0:0H
    6 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 mm_percpu_wq
    7 root      20   0       0      0      0 S   0.0  0.0   0:08.87 ksoftirqd/0
    8 root      20   0       0      0      0 I   0.0  0.0   3:48.36 rcu_sched
    9 root      20   0       0      0      0 I   0.0  0.0   0:00.00 rcu_bh
   10 root      rt   0       0      0      0 S   0.0  0.0   0:00.04 migration/0
   11 root      rt   0       0      0      0 S   0.0  0.0   0:00.49 watchdog/0
   12 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/0
   13 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/1
   14 root      rt   0       0      0      0 S   0.0  0.0   0:00.53 watchdog/1
   15 root      rt   0       0      0      0 S   0.0  0.0   0:00.04 migration/1
   16 root      20   0       0      0      0 S   0.0  0.0   0:01.54 ksoftirqd/1
   18 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 kworker/1:0H
   19 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/2
   20 root      rt   0       0      0      0 S   0.0  0.0   0:00.53 watchdog/2
   21 root      rt   0       0      0      0 S   0.0  0.0   0:00.04 migration/2
   22 root      20   0       0      0      0 S   0.0  0.0   0:08.10 ksoftirqd/2
   24 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 kworker/2:0H
   25 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/3
   26 root      rt   0       0      0      0 S   0.0  0.0   0:00.55 watchdog/3
   27 root      rt   0       0      0      0 S   0.0  0.0   0:00.04 migration/3
   28 root      20   0       0      0      0 S   0.0  0.0   0:06.01 ksoftirqd/3
   30 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 kworker/3:0H
   31 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/4
   32 root      rt   0       0      0      0 S   0.0  0.0   0:00.55 watchdog/4
   33 root      rt   0       0      0      0 S   0.0  0.0   0:00.04 migration/4
   34 root      20   0       0      0      0 S   0.0  0.0   0:01.15 ksoftirqd/4
   36 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 kworker/4:0H
   37 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/5
   38 root      rt   0       0      0      0 S   0.0  0.0   0:00.53 watchdog/5
   39 root      rt   0       0      0      0 S   0.0  0.0   0:00.04 migration/5
   40 root      20   0       0      0      0 S   0.0  0.0   0:05.88 ksoftirqd/5
   42 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 kworker/5:0H
   43 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/6
   44 root      rt   0       0      0      0 S   0.0  0.0   0:00.52 watchdog/6
   45 root      rt   0       0      0      0 S   0.0  0.0   0:00.04 migration/6
   46 root      20   0       0      0      0 S   0.0  0.0   0:02.99 ksoftirqd/6
   48 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 kworker/6:0H
   49 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/7
   50 root      rt   0       0      0      0 S   0.0  0.0   0:00.53 watchdog/7
   51 root      rt   0       0      0      0 S   0.0  0.0   0:00.04 migration/7
   52 root      20   0       0      0      0 S   0.0  0.0   0:01.23 ksoftirqd/7
   54 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 kworker/7:0H
   55 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kdevtmpfs
   56 root       0 -20       0      0      0 I   0.0  0.0   0:00.00 netns
   57 root      20   0       0      0      0 S   0.0  0.0   0:00.00 rcu_tasks_kthre
   58 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kauditd
   59 root      20   0       0      0      0 I   0.0  0.0   0:07.75 kworker/0:1
Wow, dude, your attic is sure damp!!
Thats Sydney humidity for you!
7 Seconds to load my items! That can’t be right!
I am sure that Yves will make sense of your error codes
Managed to fix a few issues, missing icons or scripts etc. They are now present and the pages load without error, mostly.
Theres still this one:
And also the 7seconds for items
Fixed the issue! at least with speed!
Hopefully Yannick can reply on those script errors @ysc
sprintf errors are likely caused by widget trying to format states of items that happen to be non-numeric at that time (i.e. NULL or UNDEF or others). They are pretty benign.
You can prevent the CSP violation error by only using server-relative URLs when including external files (like /layout/weather/example.css), provided they are on the same origin (scheme-host-port) as HABPanel.
Ive absolutely no idea what that means :frowning: All the files I load are on the same server, nothing is loaded externally that I’m aware of.
How do I change them to server relative URLs as I thought thats what Ive already got (given they are local)
