Hi, for curiosity’s sake I have some questions: Do Openhab support “follow me”, so the media can be automatically or manually routed to the room you are in? Does it support moving or copying media from a STB ( cable/satellite/terrestrial ) to a centralized storage server ( say a used HP ProLiant DL380 Generation 8 with 5 2Tb sata disks in RAID 10 configuration) automatically?
Does it support a email server ( a example, gets email from a/or external providers, routes them to internal addresses, also routes answers back to the correct external providers) If the internet is down, does it support commands from a SMS gateway ? ( should be limited to accepted SMS commands from white listed or known phone numbers, for obvious security reasons, with a included password)?
MDAR
2
Wow
I’d can’t wait to read what other people suggest for this
I can only offer thoughts on…
I use TVHeadend and a Hauppauge Dual DVB-T2 dongle for watching / recording broadcast media.
Which gives me the option to use an add-on in Kodi or any media player to watch the streams or recorded .ts files (a power machine running TVHeadend could transcode on the fly if you want smaller MKV or MP4 streams)
As for the GSM part of your question…
I guess you’d need a GSM-Gateway of some kind to give you what you need.
Good luck, it sounds like you’ve got something quite special in mind.
The only thing I know about is Rsync. It is famous for its delta-transfer algorithm, which reduces the amount of data sent over the network by sending only the differences between the source files and the existing files in the destination. It seems like it can be set up with a cronjob, but I have no idea if it can be set up with the UI . If not, maybe a function for this should be made.
Does it also support making calls? At least missed calls in case of emergencies like fire/theft.
FTR I had built a python script to render a .wav audio file over phone call via SIM900 and python GsmModem lib.
Manually isn’t too hard. You just need a button or selection or the like to indicate what room you are in.
Automatically, you can probably make something work with FIND or reelyActive to detect what room you are in and trigger rules to change the media stream to the appropriate room, assuming that your media device (Sonos, Chomecast, etc) supports migrating a media stream in the middle to a new device.
Ultimately, this won’t really be something that OH itself does, it needs to be supported by the media devices. OH will just interact with the APIs for those devices.
If the STB has a published or reverse engineered API and someone has written code to do this. I would expect this to be unlikely but anything is possible.
No. OH can send email but cannot receive email and it is not an email server.
Not that I’m aware of. But assuming there is an API to this SMS gateway it should be too hard to set something up with scripts and MQTT or OH’s REST API.
If you are limited to just UIs then I’m afraid that these goals will be beyond your ability to accomplish. You will have to get your hands dirty with scripting, coding, and the command line.
OH is not a general purpose system. OH is not a fancy GUI to manage the underlying operating system. It is primarily designed to do home automation. Some people have done a whole lot to integrate media playback and control and CCTV type capabilities with OH but it takes a lot of work and is pretty awkward. Rsync and cron are operating system things. They are, IMHO, outside the domain of what OH should be doing. Far better to use the features built into the OS for something like this.
I want to integrate this script with text to speech services of OH. So that importent announcements (fire!) can be played back over voice calls to a list of people.
