Is anybody deploying maryTTS with a German voice rendered at the right speed?
If yes, which audio sink you are using?
Seems nobody is using maryTTS with German voice, because it is not rendered correctly.
Quite a pity. It was my hope to have some TTS without cloud involved ā¦
Why not make your own?
Thanks Oli, sounds brilliant. But Iām afraid thatās beyond my capabilities
As @Kai did some refactoring of maryTTS (among his work on many, many other stuff) for openHAB2 I was hoping he is using it himselve and probably in his native language
So I was wondering how to solve it if there is indeed some issue with the German voices on maryTTS ā¦
Assuming you have some kind of Linux box running, itās actually quite simple.
The only prerequisite is a running LAMP (instructions for setting that up are just one Goggle away), and the tutorial works 100% cut&paste.
Unfortunately not - and I donāt have it anywhere at the top of my to-do list, so I would hope for somebody else that uses (or plans to use) MaryTTS to go and figure out what needs to be fixed.
marcelloceschia found the lines in the MaryTTSAudioStream.java, where the sampling rate is hard-codedā¦
Thanks marcelloceschia for looking into it!
He also proposed a quite easy solution to it, but was unable to build the bundle himself:
Since Iām not able too, Iād like to ask for somebody more experienced in Java programming than me to step in and build some jar according his proposal ā¦
Iāve build a bundle for testing https://www.dropbox.com/s/uksw9s0t2fk52qr/org.openhab.voice.marytts-2.0.0-SNAPSHOT.jar?dl=1
Just replace it and restart the openHAB service.
Excellent. Itās working!
Voice quality is not at the level of VoiceRSS, but everything remains local
Many thanks for your help @marcelloceschia !
Thank you for testing. I hope it will be tested by some other users to and we can open a pull request du fix this issue in the main branch.
Please also try to switch voices and check the result for all voices, especially the en_US voice with 48kHz sampling.
@curlyel maryTTS has a lot more voices with āother quallityā, but this can result in > 500MB library code
Iāve tested all three voices supplied with maryTTS bundle. The two German voices at 16kHz are rendered correctly as well as the English one at 48kHz. So from my point of view all fine
Regarding the āother quality voicesā:
Since nowadays the bundle is just installed on user request, an increased size of the bundle would only affect those users, who decided actively to get maryTTS installed for having TTS local. Those would accept higher disc space requirements - probably
I personally would be more than happy if could have a better TTS quality for the cost of some disc space and compute power. If youāre preparing a PR, it would be nice getting some more voices especially in higher quality in.
@marcelloceschia [quote=ācurlyel, post:91, topic:15576ā]
[/quote]
I tested it with (Build #920) version 2.1.0.201705151816 | MaryTTS Voice Service
, but both german voices are too fast, and english voice is like a bit on Valium (a bit too slow). Iāve tested it directly on OH2-Server (System Speaker with mp3 support), itās ok (all voices)!!! But when I select my āAllplay speakerā ->āDefault Sinkā in audio configuration, speed didnāt fitā¦ Is it an Allplay problem or a MaryTTS problem?
@Celaeno1 I can confirm the issue (same problem here), however I cannot see how the could be caused by the AllPlay binding. The binding is just forwarding the generated voice URL to the AllPlay speaker.
It would make sense to analyze the generated file which is sent to the speaker, however it seems like this only exists temporarily, I have no clue how to access it.
@Kai
Do you know about this issue? Maybe now itās solved for āSonosā (PR 1982 ), but āAllplayā is not running with āMaryTTS, germanā. See Post 92
No, I didnāt find time for any testing of such things in the past weeks - so I am not in the loop about any issues on that.
I donāt think there is any, so feel free to come up with fixes yourself.
@marcelloceschia I donāt know. I used it 1st time after sonos patch was published. Would it be easy for you to provide a JAR file with changed to 16 kHz? My āEcplise IDEā is too old. I have to update (or reinstall) to new version first! Thanks a lot!
@Celaeno1 you do not need the eclipse ide, yust use mvn to build the package. I can build an package with fix 16kHz sampling rate if you like to test it.
