I tried to set up a rule to be able to controll my sonos speakers. Actually, the only reason to do that was to be able to play something on all speakers at the same time.
After finding this, I was confident that this schould work:
But if I sent a command to the triggering item nothing happens. OK, in the log I get a lot of JS errors, but I will check that separately.
My main question is now, why the configuration in the “triggers” section in the rule is removed all the time.
