I’m trying to create a simple “DoorBell” action with OpenHab2 Build#703 running on synology
The Default Audio Sink is defined.
If created an item switch to trigger a rule. The rule is correctly fired but no sound is played:
rule "DingDong"
Item DingDong received command
logInfo("logInfoDingDong","DingDong Start")
setMasterVolume(new PercentType(80))
playSound("dingdong.mp3")
playSound("sonos:CONNECTAMP:RINCON_000E58DA4B7601400","dingdong.mp3")
logInfo("logInfoDingDong","DingDong End")
What’s weird, is that there is no sound played and NO error in the logs:
17:47:24.215 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'DingDong' received command ON
17:47:24.219 [INFO ] [marthome.event.ItemStateChangedEvent] - DingDong changed from OFF to ON
17:47:24.303 [INFO ] [arthome.model.script.logInfoDingDong] - DingDong Start
17:47:24.320 [INFO ] [arthome.model.script.logInfoDingDong] - DingDong End
Same with the console, command “+openhab> smarthome:audio play dingdong.mp3” No Sound, No error.
I’m not sure which volume setting the sonos binding is using for playing a sound, i nmy case (Say-command) it was the NotificationVolume. Since this chanel is hidden under “more” on PaperUI page for that thing it migth not be noticed. Try to increase that volume on your next ringing the doorbell. [Note: Doing to much test-runs with such sounds will decrease the WAF big time!!!]
Thank you.
I’ve updated my rule to set the Notification Volume to 80, but no change. No sound going out of my Sonos …
rule "DingDong"
SonosCuisineNotificationVolume.sendCommand(80)
@opus; thank you for your guidance.
I’ve set up the log level to DEBUG and here are the results:
22:42:30.134 [DEBUG] [thome.io.rest.core.item.ItemResource] - Received HTTP POST request at 'items/DingDong' with value 'ON'.
22:42:30.135 [DEBUG] [ntime.internal.engine.RuleEngineImpl] - Executing rule 'DingDong'
22:42:30.136 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'DingDong' received command ON
22:42:30.138 [DEBUG] [.sitemap.internal.SitemapEventOutput] - Sent sitemap event for widget 00 to subscription f9ceeb2f-db6e-4d6b-812d-fea524300a45.
22:42:30.139 [INFO ] [arthome.model.script.logInfoDingDong] - DingDong Start
22:42:30.139 [INFO ] [marthome.event.ItemStateChangedEvent] - DingDong changed from OFF to ON
22:42:30.141 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'SonosCuisineNotificationVolume' received command 80
22:42:30.142 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating command '80' for item 'SonosCuisineNotificationVolume' to handler for channel 'sonos:CONNECTAMP:RINCON_000E58DA4B7601400:notificationvolume'
22:42:30.142 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
22:42:30.143 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
22:42:30.144 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating update '80' for item 'SonosCuisineNotificationVolume' to handler for channel 'sonos:CONNECTAMP:RINCON_000E58DA4B7601400:notificationvolume'
22:42:30.151 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (String) RINCON_000E58DA4B7601400 to field 'udn' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
22:42:30.152 [DEBUG] [.smarthome.config.core.Configuration] - Setting value (Integer) 60 to field 'refresh' in configuration class org.eclipse.smarthome.binding.sonos.config.ZonePlayerConfiguration
22:42:30.160 [INFO ] [arthome.model.script.logInfoDingDong] - DingDong End
What looks strange is that I can’t see any action associated to the “playSound” command. Some actions are done for the 2 volume “rule commands” but nothing for the 2 playSound commands.
Did you try " Are you able to use the play commond from the karaf console? Using “smarthome:audio play doorbell.mp3"”
Please check on PaperUI the setting of the NotificationVolume (under Control), a setting of 80 should be a bit to loud,-)
Yes, indeed I’ve tested the karaf command without succes.
The default AudioSink is correctly setup in the paperUI and if I try:
openhab> smarthome:audio play dingdng.mp3
File 'dingdng.mp3' not found!
openhab>
No result with the correct filename
I’ve upgraded to the build #732, but no change.
I’ve also tried the karaf command with the audiosink defined (to not use the default), but no sound:
For what it’s worth: I noticed the same behaviour, starting today: say and play both stopped to work. Yesterday morning, my notifications still worked as shown in the logs, today they don’t.
First I thought there was an update responsible, however, I did not update in between.
Now that I think about it, I had a power outage however (of course just when I had disconnected my UPS for maintenance). Need to look further into this…
Following up on that: After another power loss to my RPi, everything works again. I remember that I had similar problems with the homekit and some other bundle as well. They simply didn’t do anything, no log messages execpt for restart messages, nothing.
After a couple of restarts (with no other changes), it suddently started working again…
Hum, not working right now.
Strange, looks like it’s working only one day and after an update on some Sonos items, channels or Things, the audiosink is broken.
I’m not sure if it is related, but on my system if I have too many things in the queue on a Sonos player, the audio stops working as the binding takes too long listing them. I think there is a fix in the works for this but you may try going into the Sonos PC app and clearing the queues for all of the Sonos devices in the system.
@yphyph01 please try the console command with doorbell.mp3, we don’t know dingdong.mp3. I am sure that doorbell.mp3 is working.
Another MP3 file was recently added in conf/sounds and I noticed that no sound was played when I tried it. Should try again.
Regarding your rule, I think it could be a problem to call playSound a second time while the first is probably
not yet finished. Of course if you are addressing not the same audio sink, that should be OK.
@Lolodomo
I’ve already tried with the standard doorbell MP3 file but same symptoms.
The MP3 file is not the issue.
For the rule, I’ve modified it following your advice. Only one playSound command … I will update it with several audio sinks, when at least one will work.
@Lolodomo
My Dingdong file is played perfectly in direct on the Sonos system as well as the Doorbell one.
Its characteristics are 172 bitrate, 48000 Hz in mode joint stereo
But with the barking file, I can not play it on Sonos. The system says that it can not play 11025Hz files.
For my issue with openhab audio sinks, I’ve tried @Mike_Bagdanoff advice and … It works. Once cleaned, the Karaf commands and my rule are play on Sonos audio sinks. So I guess there is an issue between openhab and Sonos queue management.
