I used to be able to change the volume of the TTS voice using the setMasterVolume( Float or Percent value) command.
Trying it now again (on #627) the command doesn’t have an effect anymore.
The getMasterVolume command returns the value I have set, but it does not change the volume.
The speakers volume does change to a different value for the TTS output and back to the original one after the spoken text, so there has to be another way/value the change that.
[Edit]:Did some more testing, which showed that setMasterVolume doesn’t work for grouped Sonos Players. I’m not sure if that effects Sonos devices only.
For your information, you have a channel to define the volume used for sound notification (TTS is one case of sound notification).
That didn’t come into my mind.
However, when initially testing it, setMasterVolume did work on my stereo pair. I had lots of tries there, because I didn’t know the syntax ( either use 10F, for float or New Percentage (10)).
I’ll try to use that channel on the weekend.
