openhablog1.log.zip.xml (523.7 KB)
Can you look on this log? I believe something goes wrong here.
With TRACE enabled the log is very long, however in this part it is the last time I see “Cur State: vol=90” next time in log “Cur State: vol=0”.
Which version are you running? The version with the fix shouldn’t be throwing this exception anymore.
2018-12-10 07:07:21.661 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - **SqueezeServerListener got unexpected exception: null
java.util.ConcurrentModificationException: null
at java.util.ArrayList$Itr.checkForComodification(ArrayList.java:909) ~[?:?]
at java.util.ArrayList$Itr.next(ArrayList.java:859) ~[?:?]
at org.openhab.binding.squeezebox.internal.handler.SqueezeBoxServerHandler.updatePlayer(SqueezeBoxServerHandler.java:1010) ~[191:org.openhab.binding.squeezebox:2.4.0.201811121430]
at org.openhab.binding.squeezebox.internal.handler.SqueezeBoxServerHandler.access$8(SqueezeBoxServerHandler.java:1008) ~[191:org.openhab.binding.squeezebox:2.4.0.201811121430]
at org.openhab.binding.squeezebox.internal.handler.SqueezeBoxServerHandler$SqueezeServerListener.handlePlaylistMessage(SqueezeBoxServerHandler.java:863) ~[191:org.openhab.binding.squeezebox:2.4.0.201811121430]
at org.openhab.binding.squeezebox.internal.handler.SqueezeBoxServerHandler$SqueezeServerListener.handlePlayerUpdate(SqueezeBoxServerHandler.java:577) ~[191:org.openhab.binding.squeezebox:2.4.0.201811121430]
at org.openhab.binding.squeezebox.internal.handler.SqueezeBoxServerHandler$SqueezeServerListener.run(SqueezeBoxServerHandler.java:444) [191:org.openhab.binding.squeezebox:2.4.0.201811121430]
M7 is a milestone release. Milestone releases are done about monthly (snapshots are daily).
M7 should have the fix, and it definitely doesn’t produce some of the debug messages in the log file you posted above. If the squeezebox binding is not in your addons directory, you may need to stop OH, then clear tmp and cache.
OK, it looks like for some reason there are still 2 addons installed. I’m sorry for wasting your time, I will clean my installation and go back to you next time.
