Sitemaps in BasicUI running on OH 3.3.0 sooner or later show the message :
‘SSE subscription failed: running in fallback mode’.
A restart of openHAB solves the problem for some time until it appears again.
System configuration:
- Openhabian 64bit on Raspberry PI 4B / 4GB
- Openhab 3.3.0
- Two sitemaps in BasicUI opened from Firefox / Windows 10
- Local network connection, no proxy
There are some threads around adressing the same issue but it doesn’t seem that the problem has been solved. To provide some more information with which hopefully someone else can work I have the log output of ‘org.openhab.core.io.rest.sitemap’ switched to DEBUG.
Results:
When the error message appears, the log shows that the maximum number of 50 subscriptions is reached.
With a small stress test the issue can be reproduced:
Open two sitemaps, wildly jump forth and back to child and from parent pages. Use the back arrow to go back to the previous page. Immediately after the last click close both browser windows.
The logs from the test are listed below. They show that the session already starts with 7 stale subscriptions from previously closed sessions and ends with 8.
Any ideas how to solve this problem?
Open first sitemap in browser
2022-12-10 12:17:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:18:48.817 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Created new subscription with id 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 (8 active subscriptions for a max of 50)
2022-12-10 12:18:48.819 [DEBUG] [est.sitemap.internal.SitemapResource] - Client from IP 192.168.178.30 requested new subscription => got id 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:48.971 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (8 active subscriptions}
2022-12-10 12:18:48.971 [DEBUG] [est.sitemap.internal.SitemapResource] - Client from IP 192.168.178.30 requested sitemap event stream for subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:49.625 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:49.768 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:49.771 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:50.499 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0004 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
open second sitemap in browser
2022-12-10 12:18:50.552 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Created new subscription with id c2fe6233-09e3-4e8b-bacb-133509105662 (9 active subscriptions for a max of 50)
2022-12-10 12:18:50.555 [DEBUG] [est.sitemap.internal.SitemapResource] - Client from IP 192.168.178.30 requested new subscription => got id c2fe6233-09e3-4e8b-bacb-133509105662.
2022-12-10 12:18:50.827 [DEBUG] [est.sitemap.internal.SitemapResource] - Subscription id c2fe6233-09e3-4e8b-bacb-133509105662 does not exist.
2022-12-10 12:18:50.832 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:50.989 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:52.753 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:52.753 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:18:53.451 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0200 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:19:06.272 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent alive event to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:10.618 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:10.831 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:10.992 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:11.752 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:12.620 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:12.695 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page 0302 of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:12.780 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:12.780 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:12.960 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0304 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:12.969 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0305 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:13.616 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:13.684 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page Heizung of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:13.753 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:13.753 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:14.617 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page 0300 of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:14.622 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:14.781 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:14.781 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:15.596 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page Heizung of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:15.644 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:15.816 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:17.752 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:17.752 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:17.975 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0200 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:19.353 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:19.626 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:19.774 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:21.750 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:21.750 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:22.289 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0201 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:28.812 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page 0302 of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:29.928 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page Heizung of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:31.956 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page 0301 of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:33.220 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page Heizung of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:34.335 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page 0303 of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:35.506 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page Heizung of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:36.186 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page 0305 of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:38.229 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:38.609 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:38.752 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:38.752 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:39.141 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0202 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:40.559 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:40.624 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:40.771 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:40.773 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:41.370 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0201 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:42.661 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:42.754 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:42.756 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:43.596 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0203 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:44.496 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:44.612 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:44.749 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:44.751 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:45.278 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0200 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:46.219 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:46.610 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:46.761 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:46.763 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:47.354 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0202 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:50.112 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page Heizung of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:51.120 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription c2fe6233-09e3-4e8b-bacb-133509105662 changed to page 0302 of sitemap Heizung (9 active subscriptions}
2022-12-10 12:19:53.941 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:54.612 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:54.768 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:54.770 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:55.605 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:55.741 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:55.742 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:56.002 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0201 of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:57.107 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page Photovoltaik of sitemap Photovoltaik (9 active subscriptions}
2022-12-10 12:19:57.604 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0100 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:57.743 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0003 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:57.743 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent sitemap event for widget 0002 to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:19:58.208 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 changed to page 0202 of sitemap Photovoltaik (9 active subscriptions}
Both browser tabs closed
2022-12-10 12:21:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:21:06.272 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent alive event to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:23:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:23:06.272 [DEBUG] [est.sitemap.internal.SitemapResource] - Sent alive event to subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6.
2022-12-10 12:23:11.026 [DEBUG] [est.sitemap.internal.SitemapResource] - SSE connection for subscription 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 has been closed.
2022-12-10 12:23:11.027 [DEBUG] [t.sitemap.SitemapSubscriptionService] - Removed subscription with id 0e1234f1-9e6c-4cd4-bdc7-286e243985c6 (8 active subscriptions)
2022-12-10 12:25:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:27:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:29:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:31:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:33:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:35:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:37:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:39:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:41:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2022-12-10 12:43:06.271 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
