Hey there,
I try to connect via ssh “sudo ssh openhab@localhost” to log in with the password “habopen” but it didn’t work.
Is it possible to reset the password, or does there exist another one?
thank you
Hey there,
thank you
Add -p 8101 to the ssh command
If you are using openHABian try openhabian
Did you ever get it to work?
I have simular problem, allthough I have changed the password. Afterwards I cant connect
Using hasslefree openhabian on a Rpi.
Could you try this?
openhab-cli console
And than put the new or old password.
Example:
root@raspberrypi:~# openhab-cli console
Logging in as openhab
Password:
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.2.0
Release Build
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
I cant get that far as I cant log in at all. Dont know what to do.
i´m trying to use Putty, logging in with openhabian username.
Mmm… you need a “password recovery”.
You can try this:
Already tried that. It doesn´t work.
I created a new thread to keep this simple for my situation. The thread is here:
