Setpoint is also stopped working - clicking on Up/Down arrows gives no result in Classic UI (but event is still logged). Here browser refresh does help a bit - value gets changed after refresh.
Goup All
Group Temperatures (All)
Number TargetTemp "Target Temperature [%d °C]" <temperature>
Switch Delayed_Start
Switch Heater "WebControl test" <heating> { http=">[ON:POST:http://192.168.5.236/api/setttloutput.cgi?output=1&state=1] >[OFF:POST:http://192.168.5.236/api/setttloutput.cgi?output=1&state=0]" }
Number TemperatureOffice "Ambient Temperature [%.1f °C]" <temperature> (Temperatures) { http="<[http://192.168.5.236/gett1.cgi:60000:REGEX(.*?(\\d+\\.\\d).*)]", mqtt=">[rpilocalbroker:myhouse/office/temperature:state:*:default]" }
And the rule:
// Rule to drive the Heater
rule "Heater"
System started or
Item TemperatureOffice received update or
Item TargetTemp received update
if (Delayed_Start.state == ON) {
if((TemperatureOffice.state as DecimalType)+1 < (TargetTemp.state as DecimalType)) {
if(Heater.state != ON) Heater.sendCommand(ON)
else {
if(Heater.state != OFF) Heater.sendCommand(OFF)
My initial attempt to check your observations appears to confirm your experience. I took your items, sitemap and rule, made a few small changes (see below), and loaded them on a very vanilla openHAB 1.8.1 installation. They performed correctly as I expected that they would.
Then I performed a sudo apt-get update; sudo apt-get upgrade which installed openhab-runtime 1.8.2 over openhab-runtime 1.8.1. This step restarted the openHAB runtime.
Upon reloading the UI (which was very slow, but might have been due to a network situation), the UI was no longer updating the setpoint or the heater switch. The files I used for my test are below.
Goup All
test.rules:
import org.openhab.core.library.types.DecimalType
rule "Heater"
//if (Delayed_Start.state == ON) {
else {
rule Startup
System started
TargetTemp.postUpdate(15)
TemperatureOffice.postUpdate(15)
…adding, that the behavior is the same problem after, so it doesn’t appear to be an apt-get upgrade issue.
