abraunisch
(Andreas Braunisch)
January 12, 2017, 7:13am
1
Since a few days there are a problem to download the openhab2 installation package with
the Package Center of the DSM 6
I used the OpenHAB-2.0.0.008-SNAPSHOT-DSM6-syno-noarch-0.001.spk from GitHub but get the following error message:
There was a probelm downloading openhab-offline-2.0.0-SNAPSHOT.zip from the official donwload link, wich was “https://openhab.ci.cloudbees.com/job/openHAB-Distribution/lastSuccessfulBuild/artifact/distributions/openhab-offline/target/openhab-offline-2.0.0-SNAPSHOT.zip ”
spy0r
(Stefan)
January 12, 2017, 7:18am
2
timg
(Tim Gieseler)
January 13, 2017, 2:54am
3
Synology package manager throws an error “Invalid file format” with the linked .zip file.
Discussion with some successful quick fixes, looks like the Synology build needs to be tweaked: Package fails to install since openhab has been moved to a single distro · Issue #43 · openhab/openhab-syno-spk · GitHub
bun
(Ben)
January 13, 2017, 4:22am
4
See the last two entries in this post
Hi.
@cniweb , please fix Synology package regarding to new changes and thank you for your work.
cniweb
(Christian Häussler)
January 24, 2017, 8:12pm
5
I released 2 new versions:
2.0.0.001-DSM6 (Final 2.0.0)
2.1.0.001-SNAPSHOT-DSM6 (SNAPSHOT 2.1.0)
Try it, please.
Thanks,
Chris
Guys , just to mention , there are allot of persons on 5.2 and not on DSM 6.0
so we cannot join the openhab 2 for the moment.
any release planned for 5.2 ?
Tried yesterday, downloading still a problem as well as finding the zip in the public.
Also it does not start
Lucky
(Alex)
January 28, 2017, 6:08pm
8
Hey,
i had the same Problem - and today i found the solution for me.
Please connect with Putty to your Synology and use the following command:
`sudo ipkg remove wget`
After i used this i had no more Problem to install openHAB2 on my 214play.
I hope, this works for you too.
Ah - and if you can´t open the XXX.XXX.XXX.XXX:8080 after installation - reboot your Synology.
Greetings
Alex
cniweb
February 6, 2017, 10:28pm
9
@wolf_from_the_north yes, I plan it. Do you need 2.0.0 Stable or 2.1.0 SNAPSHOT? Or both?
I would like to see both as now i am using the beta installer script with latest stable zip
Kindest regards
cniweb
February 6, 2017, 11:00pm
11
wolf_from_the_north:
Wath is this? Your own script? Can you post it?
Dear i believe its yours.
On the official downloadpage i found a beta spk for syno 5.2
I used that installer together witht the zipfile of the official release.
And that worked perfect.
Checking the files i saw that karaf was in a different map, so i believe thatthere must be a small difference.
Kindest regards
I had problems to reach the web interface. After deinstalling “webstation” on my synology nas it works.
