@hayta78
Maybe the path on ubuntu is another. check how to install bindings manually for your system and use the correct version of the binding.
@SteveBuckell
T110 should be discovered by the hub automaticly…
So if the hub is working and it should come into inbox. If you ad it manually you need to configure the hub as bridge.
@Wyskens
Fix will be applied if the PR will be merged.
Just updated from OH 4.1.0M4 to final OH 4.1.0.
I removed the 4.1.0 SNAPSHOT.jar from add-on folder which fix the Secured KLAP HTTP Protocol issue in 4.1.0M4.
I assumed in final 4.1.0 this fix is included but after upgrade and reinstalled the original 4.1.0 binding, this feature disappeared again
Did I miss anything ?
I have the same issue after upgrade to OH4.1 and add this binding (copy it into the add-on folder like described on github).
Problem is that the add-on from the add-on package is registered in OH. Do following steps :
sudo openhab-cli console
… enter the password of the openhab account - mostly habopen
list -s
… search for the tado add-on and the id-number in front of the entry
bundle:uninstall xxx
… xxx is the id number
logout
Did you remove the “standard” binding which comes with oh 4.1 add-ons via cli ? You can check this if you edit the thing and in advanced mode you have no klap protokoll to select - then the oh binding is ative and not this one.
The jar version I got from here (GitHub - wildcs/oh3_compiled-addons at tapocontrol)
does not work for me (openHAB 4.1.0).
I then went back to a version from September that I still had which works. The version is also larger 480kB while a the one from the link is has only 150kB.
hi all,
I have a P105 unit and until few months ago it was working in OH3.
Then suddenly stopped working. Reading this thread I understand that it was caused by a firmware upgrade. And that the solution will work only in OH4.
So now I have upgraded to OH4.1 in order to use again this binding, but it still doesn’t work.
And reading in the thread it seems that someone managed to have it working and someone hasn’t.
My unit (P105) has firmware version 1.2.1 build 230804 rel.190922
There are no other firmware upgrades.
The new version is still not merged in official OH4.1.
You have to install manually the jar from my compiled-addons git. It was discussed here more than once how to install.
I am using the new jar and changed to new klap protocol. For a minute or so everything works (ONLINE) and is reachable (L920 Strips) but then I get the error
encrypting failed (9500)
If I disable and enable it is working for a minute and then the same error appears.
The funny thing is that apparently the developer has already developed the new version, but it’s not included in the stable version.
I know I could install it manually from the .jar, but I will never again install manually a .jar. I did it in the past then I had to rebuild all my system from scratch due to unrecovable errors.
