Hello together,
How do I get Tasmota in Openhab? I have already connected Tasmota with my MQTT Broker. This is a Generic Module here are 4 relays connected. How do I define the items and the sitemap ?
If you are using the latest MQTT binding, you can start by creating thing inside the binding definition and then create items that refer to the things you just created. Check out the MQTT binding documentation.
I tried to create a getting started tutorial, which might help:
