19:37:06.487 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent UNREGISTERING - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.udp, component.name=org.openhab.binding.tcp.protocol.udp, component.id=3, service.id=302, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:37:06.498 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent STOPPING - org.openhab.binding.tcp
19:37:06.506 [DEBUG] [ab.binding.tcp.internal.TCPActivator] - TCP/UDP binding has been stopped.
19:37:06.511 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent STOPPED - org.openhab.binding.tcp
19:37:06.568 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.tcp.protocol.TCPBindingProvider}={component.name=org.openhab.binding.tcp.protocol.tcpgenericbindingprovider, component.id=194, service.id=334, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:37:21.720 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.tcp, component.name=org.openhab.binding.tcp.protocol.tcp, component.id=195, service.id=336, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:37:21.721 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Listening for incoming connections on /0:0:0:0:0:0:0:0:25001
19:37:21.724 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The preamble for all write operations will be set to the default vaulue of ""
19:37:21.768 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.tcp.protocol.UDPBindingProvider}={component.name=org.openhab.binding.tcp.protocol.udpgenericbindingprovider, component.id=196, service.id=337, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:37:36.869 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.udp, component.name=org.openhab.binding.tcp.protocol.udp, component.id=197, service.id=339, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:37:36.877 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent STARTING - org.openhab.binding.tcp
19:37:36.881 [DEBUG] [ab.binding.tcp.internal.TCPActivator] - TCP/UDP binding has been started.
19:37:36.891 [INFO ] [g.tcp.AbstractDatagramChannelBinding] - Listening for incoming data on /0:0:0:0:0:0:0:0:25001
19:37:36.895 [INFO ] [ing.tcp.protocol.internal.UDPBinding] - The preamble for all write operations will be set to the default vaulue of
19:37:36.936 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent STARTED - org.openhab.binding.tcp
openhab> log:display org.openhab.binding.tcp
19:35:22.796 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.tcp.protocol.TCPBindingProvider}={component.name=org.openhab.binding.tcp.protocol.tcpgenericbindingprovider, component.id=0, service.id=103, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:35:22.913 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.tcp.protocol.UDPBindingProvider}={component.name=org.openhab.binding.tcp.protocol.udpgenericbindingprovider, component.id=2, service.id=104, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:35:22.921 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent [unknown:512] - org.openhab.binding.tcp
19:35:23.793 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent STARTING - org.openhab.binding.tcp
19:35:23.799 [DEBUG] [ab.binding.tcp.internal.TCPActivator] - TCP/UDP binding has been started.
19:35:23.805 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent STARTED - org.openhab.binding.tcp
19:35:59.830 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.tcp, component.name=org.openhab.binding.tcp.protocol.tcp, component.id=1, service.id=301, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:35:59.832 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Listening for incoming connections on /0:0:0:0:0:0:0:0:25001
19:35:59.857 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The preamble for all write operations will be set to the default vaulue of ""
19:35:59.976 [ERROR] [org.openhab.binding.tcp ] - [org.openhab.binding.tcp.protocol.udp(3)] The deactivate method has thrown an exception
java.lang.NullPointerException
at org.openhab.binding.tcp.AbstractDatagramChannelBinding.deactivate(AbstractDatagramChannelBinding.java:733)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497)[:1.8.0_65]
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)
at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)
at org.apache.felix.scr.impl.manager.SingleComponentManager.disposeImplementationObject(SingleComponentManager.java:342)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.deleteComponent(SingleComponentManager.java:157)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.ungetService(SingleComponentManager.java:913)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.ungetService(SingleComponentManager.java:902)[35:org.apache.felix.scr:2.0.2]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$2.run(ServiceFactoryUse.java:260)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$2.run(ServiceFactoryUse.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_65]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryUngetService(ServiceFactoryUse.java:258)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.ungetService(ServiceFactoryUse.java:160)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.ungetService(ServiceConsumer.java:50)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.ungetService(ServiceRegistrationImpl.java:581)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.ungetService(ServiceRegistry.java:540)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.ungetService(BundleContextImpl.java:661)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.delegateAddService(ResourceTracker.java:48)[13:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:40)[13:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:869)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:857)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:915)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:715)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:753)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:700)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[35:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[35:org.apache.felix.scr:2.0.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
19:36:00.215 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.udp, component.name=org.openhab.binding.tcp.protocol.udp, component.id=3, service.id=302, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
19:36:00.289 [INFO ] [g.tcp.AbstractDatagramChannelBinding] - Listening for incoming data on /0:0:0:0:0:0:0:0:25001
19:36:00.304 [INFO ] [ing.tcp.protocol.internal.UDPBinding] - The preamble for all write operations will be set to the default vaulue of
19:37:06.260 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent UNREGISTERING - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.tcp.protocol.TCPBindingProvider}={component.name=org.openhab.binding.tcp.protocol.tcpgenericbindingprovider, component.id=0, service.id=103, service.bundleid=10, service.scope=bundle} - org.openhab.binding.tcp
