[Telegram Binding] GetUpdates failed with error_code 404 Not Found
The error message sounds like it was not able to connect to the bot.
Please check your bot token entered.
Here is a similar thread, although slightly different error message.
Link to binding documentation.
Edit: also just checked my config, the bot token is the whole string before and after the “:”; Example: xxxxxxx346:lettersandnumbersetc.
