I’ve begun to use OH2 at my OrangePi with Ubuntu.
I have some items and no proplems with it, but i want to use notification via Telegram,
I’ve been created bot by instruction https://www.openhab.org/addons/actions/telegram/, of course add Telegram action. And i can sent to my bot message over api.telegram.com use the chatid and token. Also added nessesary command in the .rules file to rule, which i need. But. When condition is met, in console appeared message:
[WARN ] [hab.action.telegram.internal.Telegram] - Transport error: {}
java.net.ConnectException: Connection refused
chatid and token in config same as i use in api.
What its may be?
# Read http://www.instructables.com/id/Telegram-Bots-for-beginners/
# to see how to set up bots and find your chat ids
bots=my_bot
my_bot.chatId=chatidhere
my_bot.token=tokenhere
# bot2.chatId=654321
# bot2.token=yyyyyyyyyyy
i’ve renamed bot to mybot and now telegram.cfg looks like this:
bots=mybot
mybot.chatId=chatidhere
mybot.token=tokenhere
after restart OH i have same message. Nothing changed.
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
at java.net.Socket.connect(Socket.java:589) ~[?:?]
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:666) ~[?:?]
at sun.security.ssl.SSLSocketImpl.(SSLSocketImpl.java:471) ~[?:?]
at sun.security.ssl.SSLSocketFactoryImpl.createSocket(SSLSocketFactoryImpl.java:153) ~[?:?]
at org.apache.commons.httpclient.protocol.SSLProtocolSocketFactory.createSocket(SSLProtocolSocketFactory.java:82) ~[?:?]
at org.apache.commons.httpclient.protocol.SSLProtocolSocketFactory.createSocket(SSLProtocolSocketFactory.java:127) ~[?:?]
at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) ~[?:?]
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) ~[?:?]
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) ~[?:?]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) ~[?:?]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323) ~[?:?]
at org.openhab.action.telegram.internal.Telegram.sendTelegram(Telegram.java:96) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:143) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:345) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
and from PC it works, because i’m using VPN (w/o VPN OpenHab community working bad). If i turn off VPN, from PC link doe not work too. Most likely, IP was bannet by Telegram
