Dear all, @Phuong
Referring to the thread:
Bindings are online but values are still not shown in the items, i.e. NULL (I’m now on the latest Milestone build 4.2.0.M1, where the fix should be loaded). When looking at the log I think values are somehow retrieved:
2024-03-24 09:21:51.328 [DEBUG] [internal.handler.TeslaVehicleHandler] - Querying the vehicle, response : 200, OK
2024-03-24 09:21:51.331 [DEBUG] [internal.handler.TeslaVehicleHandler] - Querying the vehicle: VIN XXXXXXXXXXX
2024-03-24 09:21:51.333 [DEBUG] [internal.handler.TeslaVehicleHandler] - Vehicle state is online
2024-03-24 09:21:51.335 [DEBUG] [internal.handler.TeslaVehicleHandler] - Car has moved recently and can not sleep
2024-03-24 09:21:51.336 [TRACE] [internal.handler.TeslaVehicleHandler] - Vehicle is id XXXXXX/vehicle_id XXXXXXX/tokens [XXXXXXXXXXX]
2024-03-24 09:21:51.337 [DEBUG] [internal.handler.TeslaAccountHandler] - Invoking: vehicleData
2024-03-24 09:21:52.269 [TRACE] [internal.handler.TeslaAccountHandler] - Request : vehicleData:null yields {"id":XXXXXXX,"user_id":XXXXXXX,"vehicle_id":XXXXXXX,"vin":"XXXXXXXXXXX","color":null,"access_type":"OWNER","granular_access":{"hide_private":false,"training_wheels":false},"tokens":["XXXXXXXX"],"state":"online","in_service":false,"id_s":"XXXXXXX","calendar_enabled":true,"api_version":36,"backseat_token":null,"backseat_token_updated_at":null,"ble_autopair_enrolled":false,"charge_state":{"battery_heater_on":false,"battery_level":77,"battery_range":230.85,"charge_amps":16,"charge_current_request":16,"charge_current_request_max":16,"charge_enable_request":true,"charge_energy_added":53.9,"charge_limit_soc":100,"charge_limit_soc_max":100,"charge_limit_soc_min":50,"charge_limit_soc_std":90,"charge_miles_added_ideal":181.0,"charge_miles_added_rated":226.5,"charge_port_cold_weather_mode":null,"charge_port_color":"Off","charge_port_door_open":false,"charge_port_latch":"Blocking","charge_rate":0.0,"charge_to_max_range":true,"charger_actual_current":0,"charger_phases":null,"charger_pilot_current":16,"charger_power":0,"charger_voltage":0,"charging_state":"Disconnected","conn_charge_cable":"<invalid>","est_battery_range":169.29,"fast_charger_brand":"<invalid>","fast_charger_present":false,"fast_charger_type":"<invalid>","ideal_battery_range":184.68,"managed_charging_active":false,"managed_charging_start_time":null,"managed_charging_user_canceled":false,"max_range_charge_counter":0,"minutes_to_full_charge":0,"not_enough_power_to_heat":false,"off_peak_charging_enabled":false,"off_peak_charging_times":"all_week","off_peak_hours_end_time":1380,"preconditioning_enabled":false,"preconditioning_times":"all_week","scheduled_charging_mode":"Off","scheduled_charging_pending":false,"scheduled_charging_start_time":null,"scheduled_charging_start_time_app":1320,"scheduled_departure_time":1705647600,"scheduled_departure_time_minutes":480,"supercharger_session_trip_planner":false,"time_to_full_charge":0.0,"timestamp":1711268511730,"trip_charging":false,"usable_battery_level":77,"user_charge_enable_request":null},"climate_state":{"allow_cabin_overheat_protection":true,"battery_heater":false,"battery_heater_no_power":false,"cabin_overheat_protection":"On","climate_keeper_mode":"off","defrost_mode":0,"driver_temp_setting":22.0,"fan_status":0,"hvac_auto_request":"On","inside_temp":null,"is_auto_conditioning_on":null,"is_climate_on":false,"is_front_defroster_on":false,"is_preconditioning":false,"is_rear_defroster_on":false,"left_temp_direction":null,"max_avail_temp":28.0,"min_avail_temp":15.0,"outside_temp":null,"passenger_temp_setting":22.0,"remote_heater_control_enabled":false,"right_temp_direction":null,"seat_heater_left":0,"seat_heater_right":0,"side_mirror_heaters":false,"supports_fan_only_cabin_overheat_protection":false,"timestamp":1711268511729,"wiper_blade_heater":false},"gui_settings":{"gui_24_hour_time":true,"gui_charge_rate_units":"km/hr","gui_distance_units":"km/hr","gui_range_display":"Ideal","gui_temperature_units":"C","show_range_units":true,"timestamp":1711268511730},"vehicle_config":{"can_accept_navigation_requests":true,"can_actuate_trunks":true,"car_special_type":"base","car_type":"models","charge_port_type":"EU","dashcam_clip_save_supported":false,"default_charge_to_max":false,"driver_assist":"MonoCam","ece_restrictions":true,"efficiency_package":"Default","eu_vehicle":true,"exterior_color":"Black","front_drive_unit":"NoneOrSmall","has_air_suspension":true,"has_ludicrous_mode":false,"has_seat_cooling":false,"headlamp_type":"Hid","interior_trim_type":"AllBlack","motorized_charge_port":false,"plg":true,"pws":false,"rear_drive_unit":"Small","rear_seat_heaters":0,"rear_seat_type":0,"rhd":false,"roof_color":"None","seat_type":0,"spoiler_type":"None","sun_roof_installed":1,"third_row_seats":"None","timestamp":1711268511730,"trim_badging":"85d","use_range_badging":false,"utc_offset":3600,"wheel_type":"Base19"},"vehicle_state":{"api_version":36,"autopark_state_v2":"ready","autopark_style":"dead_man","calendar_supported":true,"car_version":"2022.8.10.17 3563a9c64f1d","center_display_state":0,"dashcam_clip_save_available":false,"dashcam_state":"<invalid>","df":0,"dr":0,"fd_window":0,"feature_bitmask":"5,0","fp_window":0,"ft":0,"homelink_device_count":1,"homelink_nearby":true,"is_user_present":false,"last_autopark_error":"no_error","locked":false,"media_state":{"remote_control_enabled":true},"notifications_supported":true,"odometer":135723.552175,"parsed_calendar_supported":true,"pf":0,"pr":0,"rd_window":0,"remote_start":false,"remote_start_enabled":true,"remote_start_supported":true,"rp_window":0,"rt":0,"santa_mode":0,"smart_summon_available":false,"software_update":{"download_perc":0,"expected_duration_sec":2700,"install_perc":1,"status":"","version":" "},"speed_limit_mode":{"active":false,"current_limit_mph":85.0,"max_limit_mph":90,"min_limit_mph":50.0,"pin_code_set":false},"summon_standby_mode_enabled":false,"sun_roof_percent_open":0,"sun_roof_state":"closed","timestamp":1711268511729,"tpms_pressure_fl":null,"tpms_pressure_fr":null,"tpms_pressure_rl":null,"tpms_pressure_rr":null,"valet_mode":false,"valet_pin_needed":true,"vehicle_name":"Rolfs Tesla"}}
Has anyone an idea? Any help would be highly appreciated
