I’ve made a temporary w.o. solution that seems to resolve the situation after getting the “Invalid session cookie” error, the next poll interval the bridge will succeed in refreshing status again.
Sorry for (maybe) a stupid question but what do I need to do fo override the existing add-on with the updated .jar-file? Just put it in the addons-folder?
I’m using the 3.1 release in a docker container and get disconnected after a day of operation.
Put it in the addons folder and then login to the karaf console (different ways of doing it depending on how you run OH) typically by doing: (default password is habopen)
[13:30:38] openhabian@openhab:~$ openhab-cli console
Logging in as openhab
Password:
_ _ _ ____
___ ___ ___ ___ | | | | / \ | __ )
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
|_| 3.1.0 - Release Build
Use '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
To exit, use '<ctrl-d>' or 'logout'.
This evening the verisure binding (the 3.2.0 as per previous post) stopped working, and the log fills up with entries as per below. As the binding goes bananas hammering the verisure page, I seem to reach some kind of maxium tries in a few seconds, and cannot reach “my pages” from the same IP for an hour or so.
Anyone else experiencing any issues? I have not done any changes for the last few days, so this just suddenly happened out of the blue.
2021-09-08 20:33:04.586 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to set session cookie and auth login, HTTP result code: 503
2021-09-08 20:33:04.588 [WARN ] [ternal.handler.VerisureBridgeHandler] - Failed to initialize bridge, please check your credentials!
2021-09-08 20:33:04.934 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to set session cookie and auth login, HTTP result code: 503
2021-09-08 20:33:04.936 [WARN ] [ternal.handler.VerisureBridgeHandler] - Failed to initialize bridge, please check your credentials!
2021-09-08 20:33:05.202 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to set session cookie and auth login, HTTP result code: 503
2021-09-08 20:33:05.203 [WARN ] [ternal.handler.VerisureBridgeHandler] - Failed to initialize bridge, please check your credentials!
2021-09-08 20:33:05.504 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to set session cookie and auth login, HTTP result code: 503
2021-09-08 20:33:05.505 [WARN ] [ternal.handler.VerisureBridgeHandler] - Failed to initialize bridge, please check your credentials!
2021-09-08 20:33:05.867 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to set session cookie and auth login, HTTP result code: 503
2021-09-08 20:33:05.868 [WARN ] [ternal.handler.VerisureBridgeHandler] - Failed to initialize bridge, please check your credentials!
2021-09-08 20:33:06.144 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to set session cookie and auth login, HTTP result code: 503
2021-09-08 20:33:06.146 [WARN ] [ternal.handler.VerisureBridgeHandler] - Failed to initialize bridge, please check your credentials!
2021-09-08 20:33:06.431 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to set session cookie and auth login, HTTP result code: 503
2021-09-08 20:33:06.432 [WARN ] [ternal.handler.VerisureBridgeHandler] - Failed to initialize bridge, please check your credentials!
2021-09-08 20:33:06.725 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to set session cookie and auth login, HTTP result code: 503
2021-09-08 20:33:06.726 [WARN ] [ternal.handler.VerisureBridgeHandler] - Failed to initialize bridge, please check your credentials!
I can confirm the same issue, something has been changed on the Verisure side today.
My temp w.o. does no longer work and I need to look into a full MFA solution, I will spend some time the coming week-end on this. I will keep you posted!
Verisure has added an option to turn off MFA and you can do that per user.
Hence you can create a specific user that you then use for automation that can have MFA deactivated, if you want to use MFA on your primary account. I looks like that the user needs to be an administrator to be able to deactivate MFA.
What is interesting is that when you deactivate MFA on a user, Verisure gives you the possibility to answer questions on 3rd part integrations which indicates that they maybe will have an open API in the future.
To deactivate MFA on a user, you need to log in to the Web application MyPages and the go to your account settings:
Is there any updated version for OH3? I tried installing the latest binding you posted (3.2.0 SNAPSHOT) and I get some Import-Package error. I guess this is because I run OH3 and not OH2?
Error starting bundle 335: Could not resolve module: org.openhab.binding.verisure [335]
Unresolved requirement: Import-Package: javax.measure; version="[2.1.0,3.0.0)"
I put the 3.2.0…jar on my system. The bridge now connects without any problems and it comes online, which it was not doing before I disabled / enabled it a few times to double check it and it worked every time. However, the channels of the Things are not updating (this was also happening before), and I see this list of errors in the log file every time I re-enable the bridge:
2021-09-15 21:18:56.999 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to query for climate status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
2021-09-15 21:18:57.151 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to query for climate status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
2021-09-15 21:18:57.298 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to query for climate status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
2021-09-15 21:18:57.572 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to query for climate status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
2021-09-15 21:18:57.721 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to query for climate status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
2021-09-15 21:18:57.788 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to send a POST to the API Invalid session cookie
2021-09-15 21:18:57.852 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to send a POST to the API Invalid session cookie
2021-09-15 21:18:57.914 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to send a POST to the API Invalid session cookie
2021-09-15 21:18:57.979 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to send a POST to the API Invalid session cookie
2021-09-15 21:18:58.048 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to send a POST to the API Invalid session cookie
2021-09-15 21:18:58.129 [WARN ] [ng.verisure.internal.VerisureSession] - Failed to send a POST to the API Invalid session cookie
