@raveyd Can you turn on TRACE debug level and PM me the logs?
Actually, at midnight last night the things started regularly updating. Maybe because of previous binding problems I had reached my maximum number of requests for a day. I will check the log file again when I get a chance.
Seems like I was a bit too fast in my āokā.
Bridge is online and all things associated to it (except eventlog, which is fine if itās unrelated), however - I noticed that refresh didnāt work. I changed the refresh interval to test and then got the warning below, also notice the Forbidden for eventlog⦠Any idea what can be the cause of this? I have trace logs if needed.
2021-09-16 13:56:23.454 [DEBUG] [ng.verisure.internal.VerisureSession] - Setting cookie with username openhab@andreasbergkvist.com
2021-09-16 13:56:23.456 [DEBUG] [ng.verisure.internal.VerisureSession] - HTTP POST Request HttpRequest[POST /graphql HTTP/1.1]@1550fb7.
2021-09-16 13:56:23.526 [DEBUG] [ng.verisure.internal.VerisureSession] - HTTP Response (200)
2021-09-16 13:56:23.528 [TRACE] [ng.verisure.internal.VerisureSession] - Response body: {"errors":[{"message":"Request Failed","locations":[{"line":3,"column":2}],"path":["installation","eventLog"],"data":{"status":403,"logTraceId":"ca832e9d-b405-4a1c-bd8a-592de75bd9a9","errorGroup":"FORBIDDEN","errorCode":"AUT_00055","errorMessage":"User does not have permission to access the requested resource"}}],"data":{"installation":{"eventLog":null,"__typename":"Installation"}}}
2021-09-16 13:56:23.530 [DEBUG] [ng.verisure.internal.VerisureSession] - REST Response (VerisureBaseThingDTO [deviceId=, name=null, location=null, status=null, siteName=null, siteId=0, data=Data [installation=Installation [armState=ArmState [type=null, statusType=null, date=null, name=null, changedVia=null, allowedForFirstLine=false, allowed=false, errorCodes=[], typename=null], broadband=Broadband [testDate=null, isBroadbandConnected=false, typename=null], eventLog=null, climates=[], doorWindows=[], communicationState=[], mice=[], doorlocks=[], smartplugs=[], userTrackings=[], typename=Installation]]])
2021-09-16 13:56:23.533 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.verisure.internal.dto.VerisureBaseThingDTO$Installation.equals(VerisureBaseThingDTO.java:376) ~[?:?]
at org.openhab.binding.verisure.internal.dto.VerisureBaseThingDTO$Data.equals(VerisureBaseThingDTO.java:231) ~[?:?]
at org.openhab.binding.verisure.internal.dto.VerisureBaseThingDTO.equals(VerisureBaseThingDTO.java:150) ~[?:?]
at org.openhab.binding.verisure.internal.VerisureSession.notifyListenersIfChanged(VerisureSession.java:567) ~[?:?]
at org.openhab.binding.verisure.internal.VerisureSession.updateEventLogStatus(VerisureSession.java:942) ~[?:?]
at org.openhab.binding.verisure.internal.VerisureSession.updateStatus(VerisureSession.java:591) ~[?:?]
at org.openhab.binding.verisure.internal.VerisureSession.refresh(VerisureSession.java:127) ~[?:?]
at org.openhab.binding.verisure.internal.handler.VerisureBridgeHandler.refreshAndUpdateStatus(VerisureBridgeHandler.java:183) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_252]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:1.8.0_252]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_252]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
Is the user you are using for the automation an administrator in your system?
No, it is a user with read only permissions. Which has worked well previously.
OK, since I only use an automation user with administrator rights since I want to control my SmartLock I have not seen that fault. What happens is that the binding fails to parse the output from the eventLog since that requires ad admin user, then the NPE will cause the refresh thread to die.
I will try to fix that but then the eventLog information will not be available. What puzzles me is that the fix I have done has not touched that code, but maybe you have added the eventLog thing now?
A w.o. could then be to delete it.
Ah, I see. I only use read only data (like change in alarm state) as input to other events and therefore Iād like to run with a limited user.
As I was on a quite old version of the binding, I had not seen the eventLog thing before. I did add it, but when I saw that it wasnāt functional, I removed it. I guess that the thing is still lingering in the database even though itās removed in Paper UI.
Thanks, then I have an approach to fix this - making sure that the eventLog thing is properly removed.
As a side note, regarding MFA and a limited user. It is possible to elevate a user to administrator, disable MFA, and then lower the rights to e.g. read only again.
Cheers!
Iāve just checked that and it is possible if you lower the rights being logged in as another admin user. ![]()
Yes, thatās a good clarification of how to do it ![]()
@raveyd @AndreasB Iāve now tested with a user that is not an administrator and that it not supported by the current binding implementation since a number of endpoints that the bindings uses are not allowed to query if you are not an administrator.
That in turn leads to that the binding behaves badly and e.g. that the refresh thread is killed.
This might have worked before the latest changes that Verisure has implemented regarding authentication, so that might explain why it worked before.
For the moment I will not spend time on having support for both basic and administrator users and I will update the README that it currently is mandatory to use a user with administrator rights and with MFA deactivated.
Thank you for the update @jannegpriv.
Edit after some more testing:
@jannegpriv, it is actually possible to have a Verisure user with āRestrictedā privileges and have a functional binding (caveat, I have not tested with eventLog). So, full administrative rights seems not to be needed for my use case where I only read statuses, but the user level āMinimumā is not sufficient.
If that works for you then it is all good, when I tested I got a lot of 302ās since endpoints were not allowed to be queried, but for the official documents I will still state that you need to use a user with administrator rights. Thanks for testing! ![]()
New version for upcoming 3.2.0, code reviewed and with som bug fixes for NPEs:
3.2.0
md5sum org.openhab.binding.verisure-3.2.0-SNAPSHOT.jar
a9e6952abcbf44ede5a0ee56b2d79d6c org.openhab.binding.verisure-3.2.0-SNAPSHOT.jar
