I tried to run the openhab-config tool option 40, and i get this error:
Reading package lists... Done
W: GPG error: https://packages.grafana.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8C8C34C524098CB6
$ apt-get -y --allow-downgrades install openhab2=2.5.0~M2-1
E: Command line option --allow-downgrades is not understood
FAILED (apt)
Thanks Bruce for the super fast answer:-) The apt-get install instruction does work but says I’m already on the latest version… Should run it with -f option?
And I did the apt-get upgrade first, and only after did update the openhabian-config tool:-(
-f, --fix-broken
Fix; attempt to correct a system with broken dependencies in place. This option, when
used with install/remove, can omit any packages to permit APT to deduce a likely
solution. If packages are specified, these have to completely correct the problem. The
option is sometimes necessary when running APT for the first time; APT itself does not
allow broken package dependencies to exist on a system. It is possible that a system's
dependency structure can be so corrupt as to require manual intervention (which usually
means using dpkg --remove to eliminate some of the offending packages). Use of this
option together with -m may produce an error in some situations. Configuration Item:
APT::Get::Fix-Broken.
Yes, ok, that is what I thought and I tried it with no luck… It does not seem to change anything.
If I try to install a snaspshot from openhabian-config, then I get this error:
FAILED (apt)
And the error I have in the log with the current installation, in full version, is:
2019-08-18 14:32:09.779 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.karaf.features.internal.util.MultiException: Error:
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.dashboard/2.5.0.M2
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452) ~[?:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:393) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
Suppressed: java.io.IOException: Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.dashboard/2.5.0.M2
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:81) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
Caused by: java.lang.ClassFormatError: Truncated class file
at sun.net.idn.StringPrep.<init>(StringPrep.java:230) ~[?:?]
at java.net.IDN.<clinit>(IDN.java:240) ~[?:?]
at javax.net.ssl.SNIHostName.<init>(SNIHostName.java:99) ~[?:?]
at sun.security.ssl.Utilities.rawToSNIHostName(Utilities.java:102) ~[?:?]
at sun.security.ssl.Utilities.addToSNIServerNameList(Utilities.java:49) ~[?:?]
at sun.security.ssl.SSLSocketImpl.<init>(SSLSocketImpl.java:571) ~[?:?]
at sun.security.ssl.SSLSocketFactoryImpl.createSocket(SSLSocketFactoryImpl.java:110) ~[?:?]
at shaded.org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:365) ~[?:?]
at shaded.org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:355) ~[?:?]
at shaded.org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142) ~[?:?]
at shaded.org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:373) ~[?:?]
at shaded.org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:394) ~[?:?]
at shaded.org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237) ~[?:?]
at shaded.org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185) ~[?:?]
at shaded.org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89) ~[?:?]
at shaded.org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110) ~[?:?]
at shaded.org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185) ~[?:?]
at shaded.org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83) ~[?:?]
at org.ops4j.pax.url.mvn.internal.wagon.ConfigurableHttpWagon.execute(ConfigurableHttpWagon.java:162) ~[?:?]
at shaded.org.apache.maven.wagon.shared.http.AbstractHttpClientWagon.fillInputData(AbstractHttpClientWagon.java:1095) ~[?:?]
at shaded.org.apache.maven.wagon.shared.http.AbstractHttpClientWagon.fillInputData(AbstractHttpClientWagon.java:1072) ~[?:?]
at shaded.org.apache.maven.wagon.StreamWagon.getInputStream(StreamWagon.java:126) ~[?:?]
at shaded.org.apache.maven.wagon.StreamWagon.getIfNewer(StreamWagon.java:88) ~[?:?]
at shaded.org.apache.maven.wagon.StreamWagon.get(StreamWagon.java:61) ~[?:?]
at shaded.org.eclipse.aether.transport.wagon.WagonTransporter$GetTaskRunner.run(WagonTransporter.java:567) ~[?:?]
at shaded.org.eclipse.aether.transport.wagon.WagonTransporter.execute(WagonTransporter.java:435) ~[?:?]
at shaded.org.eclipse.aether.transport.wagon.WagonTransporter.get(WagonTransporter.java:412) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$GetTaskRunner.runTask(BasicRepositoryConnector.java:456) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:363) ~[?:?]
at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:75) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:642) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:262) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:489) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:390) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:215) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:192) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:247) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:767) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:49) ~[?:?]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) ~[?:?]
... 7 more
Any recommendation on where I should look? I searched for the error words but did not find anything that worked. I tried to downgrade but face the APT related error from openhab-config… Not sure where to look…
I had exactly this error when I was on Raspbian, version jessie.
When I upgraded the OS to version stretch, the error was no longer present and I could upgrade Openhab.
Did you double-check that you have upgraded the OS to version stretch or buster ?
cheers,
andy
Hello andy, thanks a lot for the answer. I am on Jessie, this I know.
I did work around that specific error by executing the apt-get command without the parameter but I still have the other error preventing openhab from starting.
But I’ll look at upgrading the OS, is there is luck, maybe it’ll fix both problems
I should probably add that the error came in the following context:
I had not upgraded anything for the last 4 to 5 weeks at least (latest upgrade probably in July) and I was already on 2.5 milestone, but the one from that time
I use the apt update and upgrade commands directly from the shell to upgrade until now and last week again
I did have the error mentioned and then I tried to run the config-tool driven update / upgrade but it did not fix anything…
So basically, the only thing that I did from the 2.5 milestone in July is to run apt update and upgrade from the shell, without anything else.
I hope this can help in understanding what the problem can be…
