- Platform information:
- OS: Linux
- Java Runtime Environment: 1.8.0_161
- openHAB version: 2.2.0
- Issue of the topic: The correct way to verify the config (/etc/openhab2).
How can I check the config?
Get information about:
- Syntax errors. That if I “lost” a comma or a bracket, how to find this place?
- Logical errors. That if I in “items” “contact” place parameters for the “switch”?
- Error in string of “bidings”. In MQTT the string becomes very long and complicated - it’s easy to lose a special character (sharp brackets or a colon) and make a mistake in the syntax.
- Incorrect structure. That if in “sitemap” inside the frame I specified one more frame (mistake copy-paste), how to learn about such error?
- Reference to the wrong name of the “items”. If “sitemap” indicates the old name, which is no longer in “items” list.
- how to check syntax “rule” (without run).
