David, here are some tests using rc11 with rgbww lights. All works well with the paper ui and habpanel, usually ok with the basic ui. However, the Android app accessing the same configuration setup, headless rp3 openhabian, has variable results. The logs basically show that openhab is getting the commands but not always acting on them, particularly when the app is used with “normal speed” click and drag gestures.
Hope this helps you
Paper ui and switch light on using brightness switch
15:38:57.542 [INFO ] [marthome.event.ItemStateChangedEvent] - milight_rgbwwLed_F0FE6B16A14A_2_ledcolor changed from 180,100,0 to 180,100,100
click on colour wheel
15:40:36.824 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 180,100,100 to 122,78,100
Paper ui click and drag on colour wheel
15:42:09.282 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 122,78,100 to 232,75,100
15:42:09.578 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 213,58,100
15:42:09.587 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 232,75,100 to 213,58,100
15:42:09.867 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 156,58,100
15:42:09.872 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 213,58,100 to 156,58,100
paper ui click and drag again
15:43:31.706 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 279,61,100
15:43:31.714 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 156,58,100 to 279,61,100
15:43:31.995 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 254,22,100
15:43:32.000 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 279,61,100 to 254,22,100
15:43:32.294 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 63,51,100
15:43:32.301 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 254,22,100 to 63,51,100
15:43:32.596 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 42,96,100
15:43:32.599 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 63,51,100 to 42,96,100
15:43:32.901 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 24,4,100
15:43:32.907 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 42,96,100 to 24,4,100
15:43:33.194 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 3,97,100
15:43:33.211 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 24,4,100 to 3,97,100
15:43:33.495 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 3,97,100
Start using Android app to turn light off and then back on
15:47:52.618 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TestSwitch' received command OFF
15:47:52.632 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 3,97,100 to 3,97,0
15:47:52.638 [INFO ] [marthome.event.ItemStateChangedEvent] - TestSwitch changed from ON to OFF
15:47:52.642 [INFO ] [marthome.event.ItemStateChangedEvent] - milight_rgbwwLed_F0FE6B16A14A_2_ledcolor changed from 180,100,100 to 3,97,0
15:48:01.292 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TestSwitch' received command ON
15:48:01.302 [INFO ] [marthome.event.ItemStateChangedEvent] - TestSwitch changed from OFF to ON
15:48:01.305 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 3,97,0 to 3,97,100
15:48:01.309 [INFO ] [marthome.event.ItemStateChangedEvent] - milight_rgbwwLed_F0FE6B16A14A_2_ledcolor changed from 3,97,0 to 3,97,100
several clicks on Android colour wheel (going slowly to be able to see and collect log info
15:49:35.167 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 67.01613,97.254906,100.0
15:49:35.181 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 3,97,100 to 67.01613,97.254906,100.0
15:50:42.975 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 207.82257,97.254906,100.0
15:50:42.987 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 145.8871,97.254906,100.0 to 207.82257,97.254906,100.0
15:50:44.796 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 207.58064,48.627453,100.0
15:50:44.802 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 207.82257,97.254906,100.0 to 207.58064,48.627453,100.0
15:50:45.970 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 207.90698,48.314606,34.901962
15:50:45.984 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 207.58064,48.627453,100.0 to 207.90698,48.314606,34.901962
15:50:45.988 [INFO ] [marthome.event.ItemStateChangedEvent] - Brightness changed from 100 to 34
15:50:45.992 [INFO ] [marthome.event.ItemStateChangedEvent] - milight_rgbwwLed_F0FE6B16A14A_2_ledbrightness changed from 100 to 34
15:50:47.844 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 207.90698,48.314606,34.901962
15:50:51.507 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 207.90698,48.314606,34.901962
15:50:53.201 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 313.9535,48.314606,34.901962
Click on Android colour ring, no colour change to light
15:54:06.155 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 313.9535,48.314606,34.901962
Click on Android saturation bar inside colour ring
15:55:41.032 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 314.5946,83.146065,34.901962
15:55:41.041 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 313.9535,48.314606,34.901962 to 314.5946,83.146065,34.901962
Click on Android brightness bar inside colour ring
15:56:49.525 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 315.0,82.97873,73.725494
15:56:49.544 [INFO ] [marthome.event.ItemStateChangedEvent] - Brightness changed from 34 to 73
15:56:49.555 [INFO ] [marthome.event.ItemStateChangedEvent] - RGBWWLight changed from 314.5946,83.146065,34.901962 to 315.0,82.97873,73.725494
3 separate clicks on Android colour ring and each bar at realistic user speed, no changes to light
15:57:59.330 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 315.0,82.97873,73.725494
15:58:03.509 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 315.0,82.97873,73.725494
15:58:05.775 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RGBWWLight' received command 315.0,82.97873,73.725494
