Still no response to this problem.
Openhab 3.0 and 3.0.1 did not solve the problem. Still no communication with the switch.
After upgrading Openhab to version 2.5.9 the pusbutton is not in the database anymore.
Z-Wave Node 018 (019B:0300:A306:1.26)
Unknown Device
This device has not been fully discovered by the binding. There are a few possible reasons for this -:
- The device is not in the database. If the device attributes show that this device has a valid manufacturer ID, device ID and type, then this is likely the case (eg. you see a label like " Z-Wave node 1 (0082:6015:020D::2.0) ").
Tried to add this device manually bit it conflicts with the faulty information in the database.
Anyone a solution for this, will there be a database update (or downgrade for this device, as it worked in the previous version).
