I’m trying to update to 4.1, however, afterwards my things list (created in paper-ui) is empty.
The startup logs are normal.
Only during the migration I got the errors below, however I assume, that those would not be the reason, would it?
Otherwise, how can I get to the cause of error?
[openHAB] Running JSON Database upgrade tool (${OPENHAB_RUNTIME}/bin/upgradetool.jar).
[main] INFO org.openhab.core.tools.internal.Upgrader - Copying item unit from state description to metadata in database '/var/lib/openhab/jsondb/org.openhab.core.items.Item.json'
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@234bef66'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - MultisensorOGBadTemperatur_Temperatur: Could not find thing for channel 'deconz:temperaturesensor:51430e3398:00158d00070886f2010402:temperature'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@50f8360d'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - MultisensorUGBadTemperatur_Temperatur: Could not find thing for channel 'deconz:temperaturesensor:51430e3398:00158d000588d2ee010402:temperature'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@2cb4c3ab'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - MultisensorOGBadLuftfeuchtigkeit_Luftfeuchtigkeit: Could not find thing for channel 'deconz:humiditysensor:51430e3398:00158d00070886f2010405:humidity'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@13c78c0b'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - Temperatursensortuya_Temperatur: Could not find thing for channel 'deconz:temperaturesensor:51430e3398:847127fffec2e227010402:temperature'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@12843fce'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - MultisensorUGBadLuftfeuchtigkeit_Luftfeuchtigkeit: Could not find thing for channel 'deconz:humiditysensor:51430e3398:00158d000588d2ee010405:humidity'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@3dd3bcd'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - PresenceToiletteHelligkeit_Temperatur: Could not find thing for channel 'deconz:lightsensor:51430e3398:00158d000700665c010400:temperature'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@97e1986'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - LuftfeuchtigkeitTuya_Luftfeuchtigkeit: Could not find thing for channel 'deconz:humiditysensor:51430e3398:847127fffec2e227010405:humidity'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - PresenceToiletteTemperatur_Temperatur: Could not find thing for channel 'deconz:temperaturesensor:51430e3398:fa0ff28426:temperature'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@26f67b76'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - MultisensorOGBadLuftdruck_Druck: Could not find thing for channel 'deconz:pressuresensor:51430e3398:00158d00070886f2010403:pressure'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Upgrading JS profile configuration in database '/var/lib/openhab/jsondb/org.openhab.core.thing.link.ItemChannelLink.json'
