Tibber Binding
Hi @weymann
just a heads up, I experienced the exact same thing as Sönke. What I did this morning was:
in short:
  1. unlink all items from the binding
  2. remove the thing
  3. remove the (core) Tibber binding
  4. install the (core) Tibber binding
  5. linked all (existing) items again
This resulted at first in the same thing happening: all live-items got updated, but spot-price, level and average24h stayed the same value, even though there were the “shall process timeseries” entries in the events.log (see the hidden details in my above post).
After a while and after 13:00h it reverted to normal and all three TimeSeries items got updated as expected. Nothing really in the logs (even though I set the binding to TRACE).
Oh. I just found out, that it already did change at 12:00h, sorry wasn’t aware of that. that happens to be the next full hour after I did those remove und re-install things.
2025-08-29 12:00:00.034 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TIB_Current_Total_Price' changed from 0.1711 EUR/kWh to 0.2433 EUR/kWh
2025-08-29 12:00:00.035 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ForecastSolar_Energy_Forecast' changed from 5.6259999999999994 kWh to 7.968999999999999 kWh
2025-08-29 12:00:00.036 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ForecastSolar_Power_Forecast' changed from 2226 W to 2428 W
2025-08-29 12:00:00.037 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TIB_SpotPrices' changed from 0.1711 EUR/kWh to 0.2433 EUR/kWh
2025-08-29 12:00:00.038 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TIB_SpotPrices' changed from 0.1711 EUR/kWh to 0.2433 EUR/kWh
I do have both “TIB_Current_Total_Price” and “TIB_SpotPrices” linked to the #spotPrice channel. But “TIB_SpotPrices” changed value two times within a millisecond. Perhaps that’s a hint?
But then again, I just also found out, that’s happening with the ForecastSolar binding (also the core 5.0.1 and not your Marketplace one! :wink: ) also:
2025-08-29 14:00:00.094 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ForecastSolar_Power_Forecast' changed from 2469 W to 3148 W
2025-08-29 14:00:00.095 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ForecastSolar_Power_Forecast' changed from 2469 W to 3148 W
2025-08-29 14:00:00.095 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TIB_Current_Total_Price' changed from 0.2272 EUR/kWh to 0.234 EUR/kWh
2025-08-29 14:00:00.095 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TIB_Average24h' changed from 0.28890243055555553 EUR/kWh to 0.28870833333333334 EUR/kWh
