.state before what?
CurrentDT is indeed a ZonedDateTime and it has no .state.
DefaultDay is a DateTimeItem and that is not a ZonedDateTime and cannot be used in the call to isBefore(). DefaultDay does have a .state but that’s a DateTimeType, not a ZonedDateTime so you still cannot use that in the call to isBefore(). You need to get the ZonedDateTime from that.
(DefaultDay.state as DateTimeType).zonedDateTime
See DateTime Conversion (openHAB 3.x) (
note that article remains unchanged for OH 4).
All of this works very differently in JS. There is a utility called time.toZDT() which handles converting just about anything that makes sense into a ZonedDateTime.
But no, using now.toLocalDateTime() isn’t going to change anything because a LocalDateTime doesn’t have a .state either.
Yes, see above and the link above.
