Hello
I’m new to openhab, using Version 3.1 Release edition inside a Docker container on a Synology NAS.
Using an ntp binding to my domain controller. Time in my network is 11:40. Timezone set to +1 (Zurich)
The ntp binding (datetime format) has the following pattern added inside the item: %1$td.%1$tm.%1$tY %1$tT
build a test page, left is the channel with the datetime as string, right is the one with the datetime format. As you can see there is one hour difference on the same ntp binding.
can you please give me a hint on fixing this?
Thank you
