hey guys, im slowly working through the issues with oh3 and am getting my rules back up and running. can someone please have a look over the following and let me know how the timers need to work now. I know the time side of it has changed so im hoping it should be an easy fix.
here’s the relevant parts of my rule that’s got the timers and rescheduling the timer.
2021-01-09 00:00:03.325 [INFO ] [core.model.script.Auto Office Lights] - Rule triggered
2021-01-09 00:00:03.344 [INFO ] [.model.script.Auto Office Lights New] - Turning on lights and setting timer
2021-01-09 00:00:03.655 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Auto Lights-2' failed: An error occurred during the script execution: Could not invoke method: java.time.ZonedDateTime.plusMinutes(long) on instance: 2021-01-09T00:00:03.654385+13:00[Pacific/Auckland] in Auto Lights
Here’s the complete rule. each room in my house has a similar rule.
depending on the time of day, the time the lights stay on, the brightness and colour temp of the lights are different.
side note these rules were working 100% fine before moving to oh3
var Number Office_Desk_Lights_Temp
var Number Office_Main_Lights
var Number Office_Timeout_Minutes_Use
var Timer OfficeLightsTimer = null
val int Office_Timeout_Minutes_Morning = 5
val int Office_Timeout_Minutes_Day = 5
val int Office_Timeout_Minutes_Afternoon = 5
val int Office_Timeout_Minutes_Evening = 5
val int Office_Timeout_Minutes_Night = 10
val int Office_Timeout_Minutes_Bed = 5
rule "Auto Office Lights"
Item Office_Motion changed from OFF to ON or
Item Auto_Office_Lights changed to ON
logInfo("Auto Office Lights", "Rule triggered")
Rule_Office_Lights.sendCommand(ON)
if (TimeOfDay.state == "MORNING") {
Office_Desk_Lights_Temp = 60
Office_Desk_Lights = 100
Office_Main_Lights = 100
Office_Timeout_Minutes_Use = Office_Timeout_Minutes_Morning
if (TimeOfDay.state == "DAY") {
Office_Timeout_Minutes_Use = Office_Timeout_Minutes_Day
if (TimeOfDay.state == "AFTERNOON") {
Office_Timeout_Minutes_Use = Office_Timeout_Minutes_Afternoon
if (TimeOfDay.state == "EVENING") {
Office_Timeout_Minutes_Use = Office_Timeout_Minutes_Evening
if (TimeOfDay.state == "NIGHT") {
Office_Timeout_Minutes_Use = Office_Timeout_Minutes_Night
if (TimeOfDay.state == "BED") {
Office_Desk_Lights = 60
Office_Main_Lights = 60
Office_Timeout_Minutes_Use = Office_Timeout_Minutes_Bed
if ((OfficeLightsTimer !==null) && (BYPASS_Office_LightsTimer.state !== ON) && (Someones_Home.state == ON)) {
logInfo("Auto Office Lights", "Turning on lights and rescheduling timer")
OfficeLightsTimer.reschedule(now.plusMinutes(Office_Timeout_Minutes_Use ))
Main_Office_Lights.sendCommand(Office_Main_Lights)
Office_Lamp_Left.sendCommand(Office_Desk_Lights)
Office_Lamp_Back.sendCommand(Office_Desk_Lights)
Office_Lamp_Right.sendCommand(Office_Desk_Lights)
Thread::sleep(300)
Office_Lamp_Left_Temp.sendCommand(Office_Desk_Lights_Temp)
Office_Lamp_Back_Temp.sendCommand(Office_Desk_Lights_Temp)
Office_Lamp_Right_Temp.sendCommand(Office_Desk_Lights_Temp)
postUpdate(All_Lights, ON)
createTimer(now.plusSeconds(3), [|
Rule_Office_Lights.sendCommand(OFF)
if ((OfficeLightsTimer === null) && (BYPASS_Office_LightsTimer.state !== ON) && (Someones_Home.state == ON)) {
logInfo("Auto Office Lights New", "Turning on lights and setting timer")
Thread::sleep(300)
OfficeLightsTimer = createTimer(now.plusMinutes(Office_Timeout_Minutes_Use ), [|
logInfo("Auto Office Lights", "Timer finished Turning Lights Off")
Office_Lamp_Left.sendCommand(OFF)
Office_Lamp_Back.sendCommand(OFF)
Office_Lamp_Right.sendCommand(OFF)
Main_Office_Lights.sendCommand(OFF)
I am facing currently an issue with one of my rules after upgrade to OH3 as well.
I assume it is sth. with the create timer, but I don’t have any idea. Hope someone can help me. Before the change now.plusMinutes(sollMinuten) worked like a charm. I tried it now several times.
2021-05-16 18:26:15.964 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'zigbee-2' failed: An error occurred during the script execution: Could not invoke method: java.time.ZonedDateTime.plusMinutes(long) on instance: 2021-05-16T18:26:15.962178+02:00[Europe/Berlin] in zigbee
Complete rule:
//////////////////////// 2. Wake up morning Bedroom Osram Lightstrip
var Timer Lichtweckertimer = null
rule "Schlafzimmer morning alarm Radio"
Item Lichtwecker_Osram changed
if(Lichtwecker_Osram.state == ON) {
var Number sollMinuten // define var
if(Lichtschlauch_Wecker_H.state instanceof Number) // check if value valid
sollMinuten = (Lichtschlauch_Wecker_H.state as Number).intValue * 60 // set var
else
sollMinuten = -61 // mark as invalid
if(Lichtschlauch_Wecker_M.state instanceof Number) // check if value valid
sollMinuten = sollMinuten + (Lichtschlauch_Wecker_M.state as Number).intValue // set var
else
sollMinuten = -1 // mark as invalid
if (sollMinuten >= 0 ) { // check if time valid
Lichtweckertimer?.cancel // cancel existing timer
if (sollMinuten <= (now.getHour * 60 + now.getMinute)){
sollMinuten = 1440 - (now.getHour * 60 + now.getMinute ) + sollMinuten }
else {
sollMinuten = sollMinuten - now.getMinute
Lichtweckertimer = createTimer(now.plusMinutes(sollMinuten) [|
if((ZigLightstrip_2.state as Number) < 91 && (ZigLight1_Dimmer.state as Number) < 91) { // check Level
ZigLightstrip_2.sendCommand((ZigLightstrip_2.state as Number) + 10)
ZigLight1_Dimmer.sendCommand((ZigLight1_Dimmer.state as Number) + 10) // Increase Level by 10 für deckenfluter und bettlicht
Lichtweckertimer.reschedule(now.plusMinutes(1)) // Reschedule Timer
} else { // or
Lichtwecker_Osram.sendCommand(OFF) // switch light off
logInfo("morningAlarm", "Wakeup finished")
if (Sonos_Radio_Wecken.state == ON) {
timer_Sonos_WakeUp?.cancel
timer_Sonos_WakeUp = createTimer(now.plusSeconds(5),[|
Sonos_ONE1_Volume.sendCommand(10)
Sonos_ONE1_TuneInID.sendCommand("24878")
logInfo("morningAlarm", "Wecker erstellt für {}:{} Uhr",Lichtschlauch_Wecker_H.state,Lichtschlauch_Wecker_M.state)
} else {
logWarn("morningAlarm", "Stunde oder Minute haben keinen gültigen Wert!")
} else {
logInfo("morningAlarm", "Wecker ausgeschaltet")
2021-05-16 20:35:41.674 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'zigbee-2' failed: An error occurred during the script execution: Could not invoke method: java.time.ZonedDateTime.plusMinutes(long) on instance: 2021-05-16T20:35:41.672840+02:00[Europe/Berlin] in zigbee
Got any old datetime related imports at the head of that file?
Log out sollminuten to see what you are doing.
Check you are looking at the correct rule - the second one in that file.
I only define var’s at the head of the file.
sollMinuten is providing e.g. 1252 before creating the timer. I log it at three points, this is a correct value. Is it in a wrong format? Second rule is correct. puh
No sign of that or the results in what you’ve shown us.
But don’t care really; what is its .intValue version just before you feed that to plusMinutes()?
What do you mean with .intValue version? the first time I feed sollMinuten is
at the beginning of the rule. I take it from number and convert it to .intValue. Did you mean that? Log info output for SollMinuten just before the timer creation failed was based on input parameter 1252 in my last case.
after changing the line to Lichtweckertimer = createTimer(now.plusMinutes(sollMinuten.longValue) [| I receive a different issue notification:
2021-05-17 21:42:39.144 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'zigbee-2' failed: An error occurred during the script execution: index=1, size=1 in zigbee
@rossko57@Udo_Hartmann thank you both, that helped. Recently I adjusted the code and the issue message is gone.
I am facing now the problem, that the creation of the timer is not working:
e.g. I have created a message T3 that tells me the value of SollMinuten calculated for 2 Minutes. So the system should create the timer for 2 Minutes. SollMinuten was created as .intValue.
2021-06-20 14:41:57.438 [INFO ] [org.openhab.core.model.script.Test3 ] - T3 2
2021-06-20 14:41:57.457 [INFO ] [enhab.core.model.script.morningAlarm] - Wecker erstellt für 14:43 Uhr
But I receive the following break up:
2021-06-20 14:43:57.443 [WARN ] [ore.internal.scheduler.SchedulerImpl] - Scheduled job failed and stopped
java.lang.NumberFormatException: Character , is neither a decimal digit number, decimal point, nor "e" notation exponential mark.
This is the code at this position of code:
Lichtweckertimer = createTimer(now.plusMinutes(sollMinuten.longValue) , [|
Where is my mistake? Do I have to transform the “2” again?
