Hello community,
I am new in OpenHAB and i have a question,
Is it possible to save in a text file, the date when a certain item, for example a switch, changes its state? Would it be something implemented in a rule?
Thank you
Hello community,
Thank you
Does it have to be in a text file? What’s it for?
You can use Persistence to store the state of a switch.
Or you could use another Item which follows your switch Item, and sets itself to a timestamp of the last update:
Hello hafniumzinc,
It doesn’t need to be a text file. What I want is to save the exact moment when an item changes state. In the case of an item switch, I want to save the timestamp of the change from ON to OFF and OFF to ON. That is, whenever there is a change of state.
Thank you.
If you are on OH3 then this is already happening
Thank you, I’ll check it out!
Note that the default persistence service (rrd4j) does some averaging by default; as time goes by the time periods get bigger grained. Okay for approximate times over the last week, no good for second-by-second accuracy. Other persistence services bring other options.
