Tons of Zwave errors for one node
Newbie to OH. I’ve gotten all my devices set up and they are all working great. Unfortunately my log file is FULL of errors for one Zwave node. I’m running OH v1.8.3, Zwave binding 1.8.3 on Win 7 64bit. I’m not certain what the problem is as the device appears to work fine. It does, however, appear to have an odd name when I look at it in Noepad++:
Here’s some of the errors I’m seeing:
2016-06-07 21:18:13.066 [ERROR] [b.z.i.protocol.ZWaveController] - NODE 8: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.converters.ConversionException:  : ParseError at [row,col]:[152,34]
Message: Character reference "&# :  : ParseError at [row,col]:[152,34]
---- Debugging information ----
message             :  : ParseError at [row,col]:[152,34]
cause-exception     : com.thoughtworks.xstream.io.StreamException
cause-message       :  : ParseError at [row,col]:[152,34]
class               : java.lang.String
required-type       : java.lang.String
converter-type      : com.thoughtworks.xstream.converters.SingleValueConverterWrapper
wrapped-converter   : com.thoughtworks.xstream.converters.basic.StringConverter
path                : /node/supportedCommandClasses/entry[6]/nameLocationCommandClass/name
line number         : 152
class[1]            : org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass
converter-type[1]   : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
class[2]            : java.util.HashMap
converter-type[2]   : com.thoughtworks.xstream.converters.collections.MapConverter
class[3]            : org.openhab.binding.zwave.internal.protocol.ZWaveNode
version             : 1.4.6
2016-06-07 21:18:13.332 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 8: Unsupported command class POWERLEVEL
2016-06-07 21:18:13.363 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 8: Unsupported command class POWERLEVEL
2016-06-07 21:18:13.628 [INFO ] [.c.ZWaveNodeNamingCommandClass] - NODE 8: Node name: Plug-In Dimmer
2016-06-07 21:18:13.659 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
java.lang.ArrayIndexOutOfBoundsException: 5
	at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na]
	at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na]
	at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processLocationReport(ZWaveNodeNamingCommandClass.java:242) ~[na:na]
	at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:147) ~[na:na]
	at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na]
	at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na]
	at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na]
	at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na]
	at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na]
2016-06-07 21:18:18.636 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 2 attempts left!
2016-06-07 21:18:18.636 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:18:18.651 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:18:23.643 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 1 attempts left!
2016-06-07 21:18:23.643 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:18:23.659 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:18:28.651 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 0 attempts left!
2016-06-07 21:18:28.651 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:18:28.666 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:18:33.658 [WARN ] [WaveController$ZWaveSendThread] - NODE 8: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 77 05
2016-06-07 21:18:33.690 [INFO ] [.c.ZWaveNodeNamingCommandClass] - NODE 8: Node name: Plug-In Dimmer
2016-06-07 21:18:33.721 [INFO ] [.c.ZWaveNodeNamingCommandClass] - NODE 8: Node name: Plug-In Dimmer
2016-06-07 21:18:33.736 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:18:38.728 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 2 attempts left!
2016-06-07 21:18:38.728 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:18:38.744 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:18:43.736 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 1 attempts left!
2016-06-07 21:18:43.736 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:18:43.752 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:18:48.744 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 0 attempts left!
2016-06-07 21:18:48.744 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:18:48.759 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:18:53.751 [WARN ] [WaveController$ZWaveSendThread] - NODE 8: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 77 05
2016-06-07 21:18:53.782 [INFO ] [.c.ZWaveNodeNamingCommandClass] - NODE 8: Node name: Plug-In Dimmer
2016-06-07 21:18:53.798 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:18:58.790 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 2 attempts left!
2016-06-07 21:18:58.790 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:18:58.806 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:19:03.798 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 1 attempts left!
2016-06-07 21:19:03.798 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:19:03.813 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:19:08.805 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 0 attempts left!
2016-06-07 21:19:08.805 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message.
2016-06-07 21:19:08.821 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
2016-06-07 21:19:13.813 [WARN ] [WaveController$ZWaveSendThread] - NODE 8: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 77 05
Can anyone tell me what might be going on and how to solve it? These errors repeat over-and-over again making the log file very cluttered. Thanks!
It looks like the xml file cannot be parsed/read correctly.
Back it up, then delete it and reinitialize the node. The xml file should be newly created … and hopefully can be parsed.
@sihui Thanks for the suggestions. I’ve copied the old xml file and removed it. The line read:
<name>Plug-In Dimmer&#x0;&#x0;</name>
Also that particular device’s name looks different in habmin:
Finally, how do I reinitialize? I selected the node and pressed the ‘Reinitialise Node’ button in habmin:
But nothing seems to happen. I’m using Chrome. Should that recreate the xml file? Am I doing this totally wrong?
Still getting errors even after deleting the xml and restarting:
2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - NODE 1: Node found 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - NODE 4: Node found 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - NODE 5: Node found 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - NODE 6: Node found 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - NODE 7: Node found 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - NODE 8: Node found 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - NODE 9: Node found 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller using Controller API 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------ 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - # Nodes = 7 2016-06-08 09:44:34.537 [INFO ] [rialApiGetInitDataMessageClass] - ---------------------------------------------------------------------------- 2016-06-08 09:44:34.912 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 8: Unsupported command class POWERLEVEL 2016-06-08 09:44:34.943 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 8: Unsupported command class POWERLEVEL 2016-06-08 09:44:35.177 [INFO ] [.c.ZWaveNodeNamingCommandClass] - NODE 8: Node name: Plug-In Dimmer 2016-06-08 09:44:35.208 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input. java.lang.ArrayIndexOutOfBoundsException: 5 at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processLocationReport(ZWaveNodeNamingCommandClass.java:242) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:147) ~[na:na] at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na] 2016-06-08 09:44:40.195 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 2 attempts left! 2016-06-08 09:44:40.195 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message. 2016-06-08 09:44:40.210 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input. java.lang.ArrayIndexOutOfBoundsException: 5 at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processLocationReport(ZWaveNodeNamingCommandClass.java:242) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:147) ~[na:na] at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na] 2016-06-08 09:44:45.201 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 1 attempts left! 2016-06-08 09:44:45.201 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message. 2016-06-08 09:44:45.216 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input. java.lang.ArrayIndexOutOfBoundsException: 5 at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processLocationReport(ZWaveNodeNamingCommandClass.java:242) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:147) ~[na:na] at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na] 2016-06-08 09:44:50.205 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 0 attempts left! 2016-06-08 09:44:50.205 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message. 2016-06-08 09:44:50.220 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input. java.lang.ArrayIndexOutOfBoundsException: 5 at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processLocationReport(ZWaveNodeNamingCommandClass.java:242) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:147) ~[na:na] at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na] 2016-06-08 09:44:55.220 [WARN ] [WaveController$ZWaveSendThread] - NODE 8: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 77 05 2016-06-08 09:44:55.252 [INFO ] [.c.ZWaveNodeNamingCommandClass] - NODE 8: Node name: Plug-In Dimmer 2016-06-08 09:44:55.283 [INFO ] [.c.ZWaveNodeNamingCommandClass] - NODE 8: Node name: Plug-In Dimmer 2016-06-08 09:44:55.298 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input. java.lang.ArrayIndexOutOfBoundsException: 5 at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processLocationReport(ZWaveNodeNamingCommandClass.java:242) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:147) ~[na:na] at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na] 2016-06-08 09:45:00.294 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 2 attempts left! 2016-06-08 09:45:00.294 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message. 2016-06-08 09:45:00.309 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input. java.lang.ArrayIndexOutOfBoundsException: 5 at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processLocationReport(ZWaveNodeNamingCommandClass.java:242) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:147) ~[na:na] at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na] 2016-06-08 09:45:05.304 [ERROR] [WaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 1 attempts left! 2016-06-08 09:45:05.304 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 8: Got an error while sending data. Resending message. 2016-06-08 09:45:05.320 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
Yes, it should. Maybe it is too far away from the controller???
Very odd. It is no more than 15’-20’ (4.5m-6m) away from the controller. I can see it from the controller.
Perhaps I should exclude it and then include it again?
Is it a battery operated device? Then you may need to wake it up with a button to get initialized, sometimes even several times …
< gesendet von Samsung Smartphone >
No, it’s a plug in lamp dimmer. I forced the light on just now to see if it would then reinitialize but it didn’t do anything. Does habmin log anything when you try to heal/reinitialize (if yes, where)? It just doesn’t seem like it responds when I do either of those.
Yes, but you won’t see a lot if you are not in debug mode.
Either the log messages are in openhab.log or (if you’ve set up like suggested in the wiki) in zwave.log.
But first you have to enable debug mode … start openHAB with start_debug.bat and see what the log tells you.
If your other devices are running fine I would exclude, reset the device and include it again as a last resort.
I tried in debug mode and it looks like it’s querying node 8 like crazy. I let it run for about 10 minutes and my log file kept saying the same stuff over and over again. Log file was over 60 megs when I decided to stop it. I didn’t see any errors in the debug log thought I could have overlooked them. The xml file was never written again though. How do I get this to happen?
I don’t have a zwave.log file. How do I get OH to generate this?
If you make a setup like suggested in the wiki you will have a zwave.log:
otherwise the debug messages go to openhab.log
I read that page a million times and never noticed the logging part. I got it working, but I’m still seeing that error in my openhab.log but getting other stuff in the zwave.log. It really seems like it is not liking the naming of the device:
2016-06-08 13:41:50.835 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 8: Application Command Request (ALIVE:STATIC_VALUES) 2016-06-08 13:41:50.835 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 8: Incoming command class NODE_NAMING 2016-06-08 13:41:50.835 [DEBUG] [.c.ZWaveNodeNamingCommandClass:116 ]- NODE 8: Received NodeNaming Command Class Request 2016-06-08 13:41:50.837 [ERROR] [b.z.i.protocol.ZWaveController:1173]- Exception during Z-Wave thread: Input. java.lang.ArrayIndexOutOfBoundsException: 5 at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processLocationReport(ZWaveNodeNamingCommandClass.java:242) ~[na:na] at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:147) ~[na:na] at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na] at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na]
This comes as no surprise as you can see by the screenshot above and in the strange characters after the name. Why does this device not look like the others? Why isn’t it called Node 8 like the others? It functions just fine, but keeps throwing these errors.
To be honest: I don’t know (and have never used openHAB on Windows).
Maybe you should look at this thread, it could be related to your problem:
Hmm.. the link you posted was resolved by changing the port. This doesn’t seem to be related to my problem.
Do you, or anyone, know who maintains the zwave binding? Perhaps he/she could be of help on this seemingly odd behavior.
For that you need to shout at @chris
Good luck.
If it is truly the name it is having a problem with, you should be able to manually change the name by editing the XML file. This is probably considered a bad idea but when all else fails…
Just remove the weird stuff after “Dimmer” and save the XML file. The &#x0; is an escaped character in XML/HTML and it should be a four digit HEX number so the x0 is clearly not valid.
A more important question is where did those rogue characters come from. Perhaps there is an error in the Zwave DB?
Reinitializing the node won’t help if the problem is that the zwave database is adding these rogue invalid characters to the name. It does indeed look like the binding is having a problem creating the xml file which might account for the weird invalid characters.
Hopefully chris will chime in. He will almost certainly ask for your logs.
In the mean time, assuming the rest of the XML file is valid manually editing it like this should get you past this immediate problem.
The problem is not with the database - it’s a problem with the node name.
I’ve not followed this through totally, but I see at the top of the thread that you are using 1.8.3 - please make sure that you are using 1.9. I’m not completely sure this bug is fixed in 1.9, but we should at least start from a recent version of code :wink:.
If the problem persists in 1.9, then I will sort it out as it is definitely fixed in 2.0.
Another occurrence of #4046 maybe?
Yep.
D’oh, ninja edited it to 4046. :wink:
(And now I take it back, I think it really is 4058!)
