I am trying to use Zigbee (Telegesis) to control Tradfri bulb. When I reset a bulb, I can pair it and control it from openhab. As soon as I pair the bulb with a tradfri remote control, it is not connected anymore. Is there a way to somehow pair it and still use the remote? Ideally without needing the ikea gateway?
A Zigbee device can only be a member of one Zigbee network at a time. When you connect it to the remote that means you remove it from OH.
To make this work you need to add the remote to OH and set up Rules to process the remote button presses and turn on the light. This is how you want it to work anyway so that you can control anything connected to OH with the remote, not just Tradfri devices.
Thanks for the quick response! The reason I am trying to have this is because I dont want the whole house without light if the server breaks down, but still be able to control lights from a server in normal operation. I did read something about devices being on the same network in “zigbee groups” but don’t understand that concept yet. If there is any documentation about that I would be interested.
I just got it working as you described. It’s quite a fiddle, but this is how I did it:
pair the bulb with OH/Telegesis (5/6 times on/off), test if you can control the bulb via OH
pair the remote/dimmer with OH as well (although you can only view the battery state in OH and the thing is useless in OH), this seems to be the critical step
hold the remote or dimmer close to the bulb and press and hold the connect button very close to the bulb
wait 10 seconds until the bulb stops flickering
wait a minute and try to control the bulb via OH and via remote/dimmer
repeat step 3 to 5 for every bulb you would like to pair with the remote/dimmer.
it took me almost an hour for 10 bulbs, sometimes needed to repeat steps 3 to 5 many times, but it works.
you can reset the remote/dimmer by pressing the connect button 4 or 5 times quickly. wait a bit for it to complete.
BTW: the Ikea control outlets work like a charm with the telegesis as well.
Cool, it does work. What currently does somehow not seem to work is getting the feedback of the state. If I switch on/off the bulb via remote, openhab somehow does not get any events, so I don’t know if they are on or off. But I can control them through the switch and through openhab, very cool.
Really strange. I don’t have the dimmer, but dimming via the remote control does not give me any feedback to OH. Are you also on 2.4.0.M6 with a Telegesis extr3?
