I have a Z-Wave Trane Thermostat that is bound and has items set for Set Cooling Temp, Set Heating Temp, Set Fan Mode, Set Fan State, Set Mode, Set Operating State, and Display Temp.
Everything seems to function and display properly in BasicUI, PaperUI, and HabMin except the current temp. For some reason, it seems stuck on 69.8F regardless of what’s displayed on the thermostat screen. It stays at that number almost continuously, but occasionally will display the correct temp, only rarely, and I can’t determine what initiates that.
I’ve rebooted the RaspberryPi and the OpenHabian operating system, but it doesn’t seem to resolve the issue. I’m new to this program and learning as I go. Any thoughts as to what might be occurring here and what I can do to resolve it?
I just tried to change the settings from one temp to another and also changed the setting from Heat to Auto, but nothing displayed in the Openhab.log file. The thermostat state and temp changed appropriately. The temp reading still says 69.8F even though the thermostat screen says 72F.
Is the openhab.log file the right log file for this? Is there another log file you’re referring to? Sorry for my newbie-ness.
Please use code fences when posting logs, things/items files, etc… It’s the paper icon to the left of the gear icon.
The log shows everything changing, is that correct?
I do not see temp reading (from display) please post the thing/item configuration for this. Also check in PaperUI Thing that the display channel (blue button you click) is clicked and linked. If you do not see this option look for “show more” and click it to see if there is more channels available.
I’ll check. Meantime, after almost exactly 4 minutes ( 11:49:41.731 when the temp registered correctly to 11:53.41.739 ) the temp display in OpenHab reset itself to 69.8F:
2020-01-02 11:53:41.739 [vent.ItemStateChangedEvent] - FF_Thermostat changed from 71.60 °F to 69.80 °F
The only polling parameters I see are under “Device Configuration” where the Polling Period is set to 15 seconds and the Command Poll Period is set to 100 (no designation on that one whether it’s seconds or not).
I don’t have a Trane t-stat to test with so I’m not sure what other parameters to look for. Did you ever have simple mode turned on in PaperUI? Perhaps there could be a duplicate item for the temp display.
After clean the cache and reading is not working I would try deleting all the Things/Items for the t-state, clean caceh again then rediscover again.
I’ll try the rediscovery mode idea and see if that helps. I’m wondering this myself. I had tried to set this system up over a year ago and stopped, then picked it back up again over the holidays. I did find some clashes with the cache before and multiple .items and .sitemap files that may have been conflicting with each other. I renamed them all and just went with one .items and .sitemap file and cleared the cache and rebooted. That cleared up some of the other issues, but this one seems to persist.
Thanks for the help so far! I’ll post back with some results.
I had simple mode off, but my son turned it back on. Should I turn it off and start over with everything? What does having it on do to the system settings and configs?
(I’m hoping I don’t have to do everything over again, because setting up my Schlage door locks was a major bitch).
