a have a destroyes 500er ZWaveMe hat on my Pi4B. (I think I have another of same factory)
In advice that I dont like companys who sell hardware that would not survive I am thinkig about
I know the Backup of Z-Way and have seen that a Backup with Aeon is allso possible over Windows (VM ist ok)
So know I am searching about so meenings how I could transfer nodes from one Controller to the other without including them all manually (over hardware).
Z-Way should support master and slave controllers. Is there a senario I can use that for?
I doubt that is possible or sensible. What if one controller supports features the other does not? What if the the mesh relationships work out different (the controllers may not be at the same point in space, different aerials, etc.)
I had a Razberry hat that broke. I also have a spare one just in case. I also make a backup of the devices every week with the z-way-me software and restored them to a new z-way-me stick with another Raspberry PI. Everything worked after I stuck this new Razberry with the restored devices on the Raspberry PI I run OpenHAB on.
This does work. If you add a second controller to the first one. Z-wave supports this as well. If you do this with two z-wave-me installations. Unfortunately, OpenHAB does not cater for this out-of-the-box.
The serial port can only be used by either Openhab or zwave-me.
You have to stop Openhab:
sudo systemctl stop openhab.service
Then you can install or start zwave-me:
sudo /etc/init.d/z-way-server start
The expert mode can be accessed from a webbrowser: http://yourip:8083/expert
Then you can make or restore a backup and do other things such as including new devices.
When this is done you have to stop zwave-me and restart Openhab:
