Transform in Rule
Hi
Hope you all had a good Christmas. For me it’s too much food and not enough coding.
I have a system working happily on RPI4 running OpenHAB 3 with Mosquitto MQTT Broker running and communicating on the same RPI4.
I have a number of temperature inputs which will send me a topic of
occ/location/ti
and the payload will be the number of the temperature sensor 1-8, followed by a ‘:’ followed by the temperature value, so a typical payload might be
1:11.6
Can somebody show me a rule which will allow me to ‘Switch/case’ on the first digit and extract the temperature value to forward to the relevant UI location?
Thanks as ever
You might be able to do this in your Thing Channel directly without a rule by using REGEX to filter for the sensor by looking for
1:
then chaining another REGEX transform to extract the temperature value. All of this would go in the transformationPattern of the Thing Channel. You can then create a separate Channel for each temperature sensor, adjusting your first REGEX filter to suit.
This may help:
If you must go that way, string .split(":") would be useful.
But I’d direct effort at doing it in the channel(s) by transformation, as suggested by @hafniumzinc
