Openhab is new for me, before i used Openremote.
About my question, I have a velbus network communicating over VMB1USB (with velserv) to VMB4RYNO and some glaspanels type VMBGPOD, VMBGP2,…
Before with Openremote I sended a trigger to a push button (CH1) of a VMBGPOD.
In velbuslink there are some actions programmed for that channel, for example CH1 set all glaspanels to “COMFORT” mode, or to “program1”.
Is it possible to send a trigger to a channel of a VMBGPOD with Openremote and read the status of statusled of that pushbutton?
I tried like this, but is not working.
items.
Switch PB_Press “PB_Press” (gP) {channel=“velbus:vmbgpod:956cb640:69:input#CH1”}
Group:Switch:OR(ON, OFF) gP “PushButtonPRESS” (Home)
sitemap
Switch item=PB_Press
ruele
rule “PushButton of group gP”
Item gP changed
// waiting a second.
Thread::sleep(700)
// Foreach-Switch-is-ON
gP.allMembers.filter( s | s.state == ON).forEach[i|
// switching OFF
sendCommand(i, OFF)
Item gP changed
Thread::sleep(700)
gP.allMembers.filter( s | s.state == ON).forEach[ i | i.sendCommand(OFF) ]
You had a comment in the line, therefore everything after that gets ignored
Do you use VS code to validate you code?
I will try to clarify a bit more.
For example
The red circle is a link to the channel of a pushbutton of a VMBGP4 (link not working)
The blue circle is a link to the temperature of the same VMBGP4 (link is working perfect)
How can i send a pulse to this input channel 4 (pushbutton)?
And is there a way to get the actual status of the statusled from that pushbutton?
David
MDAR
(Stuart Hanlon, UK importer of Velbus hardware)
8
Hi
I’m really sorry to say that the functionality you’re looking for doesn’t exist in the openHAB2 Velbus binding… Yet…
Cédric has done some amazing (unfunded) work on this binding and I for one am truly grateful for his efforts.
He has communicated to me that he intends to continue adding functionality, as and when his personal work load allows him the time.
I hope this goes some way to explain the difference in functionality between openHAB2 functionality and what you have experienced within OpenRemote. (The platforms are intended for slightly different end users)
Best wishes,
Stuart
MDAR
9
Hi David
Just to clarify your screenshot.
The Red circled item is a “Trigger” which can be used in a rule…
channel 'velbus:vmbgp2:***********:AA:input#CH1' triggered PRESSED // Could be RELEASED or LONG_PRESSED
Whereas your Blue circled text can be linked to an Item and as such can be used in a rule thus
Item [Item Unique Name] changed // as an example
Thanks for the reply’s, I hope that in the future there will be a solution, that would be a nice option.
Communication with VMB4RYNO is working perfect.
Bindings with Sonos, Velux and SamsungTV are also working great.
