I used to trigger my IRobot Roomba via IFTTT and the OpenHab IFTTT service.
Sadly the IFTTT service does not work since several weeks, as @digitaldan explains here: https://community.openhab.org/t/myopenhab-not-reachable/76974/84
Now I had some time to search for an alternative, and thanks to the IFTTT Webhooks Service I found a solution.
- Activate the Webhook service in your IFTTT account and create a new IFTTT applet where the Webhook is the trigger
- In an openhab rule just add a sendHttpGetRequest which sends a HTTP request to the webhook and triggers the applet
Here a short example how my IRobot (his name is “Saugi”
)is trigerred within a rule:
rule "roomba_activate_bytime"
Time cron " 0 0 11 ? * MON-FRI *" or
Time cron " 0 0 12 ? * MON-FRI *" or
Time cron " 0 0 13 ? * MON-FRI *" or
Time cron " 0 0 14 ? * MON-FRI *"
logInfo("Rule Roomba By Time","Rule Roomba started")
//Check if no Cellphone is connected to the Wifi and if the robot has already bin started
if((JensiPhone.state == CLOSED) &&
(JaninasSamsung.state == CLOSED) &&
(status_roomba_automode.state == ON) &&
(status_roomba_start.state == OFF)){
logInfo("Rule Roomba By Time", "Saugi activated")
status_roomba_start.postUpdate(ON)
var response = sendHttpGetRequest("https://maker.ifttt.com/trigger/Saugi/with/key/xxxxxxxxxxxxx")
logInfo("Rule Roomba By Time", response)
else {
logInfo("Rule Roomba By Time", "Saugi not activated")
