Trying to get IPCamera binding working with Reolink E1 Pro (ONVIF)
I’m trying to get a Reolink E1 Pro camera working with the IPCamera binding. The binding has been working with a Reolink WiFi Doorbell camera (which uses the Reolink API Thing) for over a year, so the binding appears to be working ok. However I am not able to get the E1 Pro to come online using the ONVIF IP Camera thing. (The E1 Pro does not support the Reolink API.)
After manually adding the Thing the camera is offline and displays
COMMUNICATION_ERROR
Connection Timeout: Check your IP and PORT are correct and the camera can be reached.
I have turned on the RTSP & ONVIF support in the Reolink app. I’m using the same configuration parameters that I’m using in Synology Surveillance Station, which is working with both cameras..
opehHAB 4.2.3 running in Docker on Synology NAS
IPCamera Binding 4.2.3
UID: ipcamera:onvif:GarageCamera
label: Garage Camera
thingTypeUID: ipcamera:onvif
configuration:
  mjpegOptions: -q:v 5 -r 2 -vf scale=640:-2 -update 1
  ipAddress: 192.168.20.52
  updateImageWhen: "0"
  onvifPort: 8000
  gifPreroll: 0
  ffmpegLocation: /usr/bin/ffmpeg
  ipWhitelist: DISABLE
  mp4OutOptions: -c:v copy -c:a copy
  pollTime: 1000
  password: Garage#1
  port: 80
  snapshotOptions: -an -vsync vfr -q:v 2 -update 1
  ptzContinuous: false
  onvifMediaProfile: 0
  username: admin
  hlsOutOptions: -strict -2 -f lavfi -i aevalsrc=0 -acodec aac -vcodec copy
    -hls_flags delete_segments -hls_time 2 -hls_list_size 4
  gifOutOptions: -r 2 -filter_complex
    scale=-2:360:flags=lanczos,setpts=0.5*PTS,split[o1][o2];[o1]palettegen[p];[o2]fifo[o3];[o3][p]paletteuse
channels:
  - id: startStream
    channelTypeUID: ipcamera:startStream
    label: Start HLS Stream
    description: Lower the delay to start casting the camera by creating the files
      non stop in case they are needed.
    configuration: {}
  - id: pollImage
    channelTypeUID: ipcamera:pollImage
    label: Poll Image
    description: This can be used to trigger snapshot updates when an external PIR,
      button or other form of sensor turns this channel ON.
    configuration: {}
  - id: image
    channelTypeUID: ipcamera:image
    label: Image
    description: Low frame rate image from your camera. Recommend this is NOT used
      unless you have large pollTime.
    configuration: {}
  - id: recordingGif
    channelTypeUID: ipcamera:recordingGif
    label: GIF Recording
    description: Indicates how long the recording will occur for and when the file
      is created, the channel will change to 0 by itself.
    configuration: {}
  - id: gifHistory
    channelTypeUID: ipcamera:gifHistory
    label: GIF History
    description: A history of the last GIFs created in a CSV formatted string.
    configuration: {}
  - id: gifHistoryLength
    channelTypeUID: ipcamera:gifHistoryLength
    label: GIF History Length
    description: How many GIFs are stored in the history.
    configuration: {}
  - id: recordingMp4
    channelTypeUID: ipcamera:recordingMp4
    label: MP4 Recording
    configuration: {}
  - id: mp4History
    channelTypeUID: ipcamera:mp4History
    label: MP4 History
    description: A history of the last mp4 recordings created in a CSV formatted string.
    configuration: {}
  - id: mp4HistoryLength
    channelTypeUID: ipcamera:mp4HistoryLength
    label: MP4 History Length
    description: How many mp4 recordings are stored in the history.
    configuration: {}
  - id: lastMotionType
    channelTypeUID: ipcamera:lastMotionType
    label: Last Motion Type
    description: A string that contains the type of motion alarm that was last triggered.
    configuration: {}
  - id: ffmpegMotionControl
    channelTypeUID: ipcamera:ffmpegMotionControl
    label: Control FFmpeg Motion Alarm
    description: Enable/Disable the motion alarm and control the sensitivity.
    configuration: {}
  - id: ffmpegMotionAlarm
    channelTypeUID: ipcamera:ffmpegMotionAlarm
    label: FFmpeg Motion Alarm
    description: FFmpeg has detected motion.
    configuration: {}
  - id: thresholdAudioAlarm
    channelTypeUID: ipcamera:thresholdAudioAlarm
    label: Audio Alarm Threshold
    description: By moving this control you should be able to change how sensitive
      the audio alarm is to soft or loud noises.
    configuration: {}
  - id: audioAlarm
    channelTypeUID: ipcamera:audioAlarm
    label: Audio Alarm
    description: Audio has triggered an Alarm.
    configuration: {}
  - id: externalMotion
    channelTypeUID: ipcamera:externalMotion
    label: External Motion
    description: Use any external sensor like a ZWave PIR sensor to flag that the
      camera has motion in its field of view.
    configuration: {}
  - id: motionAlarm
    channelTypeUID: ipcamera:motionAlarm
    label: Motion Alarm
    description: Motion has been detected.
    configuration: {}
  - id: cellMotionAlarm
    channelTypeUID: ipcamera:cellMotionAlarm
    label: Cell Motion Alarm
    description: Cell based motion has been detected.
    configuration: {}
  - id: lineCrossingAlarm
    channelTypeUID: ipcamera:lineCrossingAlarm
    label: Line Crossing Alarm
    configuration: {}
  - id: fieldDetectionAlarm
    channelTypeUID: ipcamera:fieldDetectionAlarm
    label: Field Alarm
    description: Intrusion has detected movement. AKA Field Detection Alarm.
    configuration: {}
  - id: faceDetected
    channelTypeUID: ipcamera:faceDetected
    label: Face Detected Alarm
    description: A face has been detected.
    configuration: {}
  - id: parkingAlarm
    channelTypeUID: ipcamera:parkingAlarm
    label: Parking Alarm
    description: A car has triggered the Parking Detection.
    configuration: {}
  - id: itemLeft
    channelTypeUID: ipcamera:itemLeft
    label: Item Left Alarm
    description: An item has been left.
    configuration: {}
  - id: itemTaken
    channelTypeUID: ipcamera:itemTaken
    label: Item Taken Alarm
    description: An item may have been stolen.
    configuration: {}
  - id: tamperAlarm
    channelTypeUID: ipcamera:tamperAlarm
    label: Tamper Alarm
    description: Camera may be stolen or damaged.
    configuration: {}
  - id: tooDarkAlarm
    channelTypeUID: ipcamera:tooDarkAlarm
    label: Too Dark Alarm
    description: Image is too dark.
    configuration: {}
  - id: storageAlarm
    channelTypeUID: ipcamera:storageAlarm
    label: Storage Alarm
    description: An issue with the cameras storage has been reported.
    configuration: {}
  - id: sceneChangeAlarm
    channelTypeUID: ipcamera:sceneChangeAlarm
    label: Scene Change Alarm
    description: Camera may have been moved.
    configuration: {}
  - id: tooBrightAlarm
    channelTypeUID: ipcamera:tooBrightAlarm
    label: Too Bright Alarm
    description: Image is too bright.
    configuration: {}
  - id: humanAlarm
    channelTypeUID: ipcamera:humanAlarm
    label: Human Alarm
    description: A person has triggered the Human Detection.
    configuration: {}
  - id: animalAlarm
    channelTypeUID: ipcamera:animalAlarm
    label: Animal Alarm
    description: An animal has triggered the object detection.
    configuration: {}
  - id: carAlarm
    channelTypeUID: ipcamera:carAlarm
    label: Car Alarm
    description: A car has triggered the Vehicle Detection.
    configuration: {}
  - id: tooBlurryAlarm
    channelTypeUID: ipcamera:tooBlurryAlarm
    label: Too Blurry Alarm
    description: Image is out of focus.
    configuration: {}
  - id: pan
    channelTypeUID: ipcamera:pan
    label: Pan
    description: Pan the camera to a new position.
    configuration: {}
  - id: tilt
    channelTypeUID: ipcamera:tilt
    label: Tilt
    description: Tilt the camera to a new position.
    configuration: {}
  - id: zoom
    channelTypeUID: ipcamera:zoom
    label: Zoom
    description: Zoom the camera to a new value.
    configuration: {}
  - id: gotoPreset
    channelTypeUID: ipcamera:gotoPreset
    label: Go To Preset
    description: Move a P.T.Z camera to this ONVIF preset location.
    configuration: {}
  - id: mjpegUrl
    channelTypeUID: ipcamera:mjpegUrl
    label: MJPEG URL
    description: A link you can use in openHAB/HABpanel to fetch a MJPEG video feed
      from the camera.
    configuration: {}
  - id: rtspUrl
    channelTypeUID: ipcamera:rtspUrl
    label: RTSP URL
    description: A link that the camera uses for RTSP.
    configuration: {}
  - id: imageUrl
    channelTypeUID: ipcamera:imageUrl
    label: Image URL
    description: A link you can use to fetch a static image from the camera.
    configuration: {}
  - id: hlsUrl
    channelTypeUID: ipcamera:hlsUrl
    label: HLS URL
    description: A link you can use in openHAB to cast video feeds.
    configuration: {}
openhab.log:
2025-01-20 17:27:54.900 [DEBUG] [ng.ipcamera.internal.IpCameraActions] - bundle org.openhab.binding.ipcamera:4.2.3 (274)[org.openhab.binding.ipcamera.internal.IpCameraActions(346)] : ServiceFactory.getService()
2025-01-20 17:27:54.901 [DEBUG] [ng.ipcamera.internal.IpCameraActions] - bundle org.openhab.binding.ipcamera:4.2.3 (274)[org.openhab.binding.ipcamera.internal.IpCameraActions(346)] : This thread collected dependencies
2025-01-20 17:27:54.901 [DEBUG] [ng.ipcamera.internal.IpCameraActions] - bundle org.openhab.binding.ipcamera:4.2.3 (274)[org.openhab.binding.ipcamera.internal.IpCameraActions(346)] : getService (ServiceFactory) dependencies collected.
2025-01-20 17:27:54.901 [DEBUG] [ng.ipcamera.internal.IpCameraActions] - bundle org.openhab.binding.ipcamera:4.2.3 (274)[org.openhab.binding.ipcamera.internal.IpCameraActions(346)] : Querying state satisfied
2025-01-20 17:27:54.901 [DEBUG] [ng.ipcamera.internal.IpCameraActions] - bundle org.openhab.binding.ipcamera:4.2.3 (274)[org.openhab.binding.ipcamera.internal.IpCameraActions(346)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2025-01-20 17:27:54.901 [DEBUG] [ng.ipcamera.internal.IpCameraActions] - bundle org.openhab.binding.ipcamera:4.2.3 (274)[org.openhab.binding.ipcamera.internal.IpCameraActions(346)] : Changed state from satisfied to active
2025-01-20 17:27:54.909 [DEBUG] [amera.internal.onvif.OnvifConnection] - Connecting 192.168.20.52 to ONVIF
2025-01-20 17:27:54.910 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetSystemDateAndTime to http://192.168.20.52:8000/onvif/device_service
2025-01-20 17:27:54.911 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetCapabilities to http://192.168.20.52:8000/onvif/device_service
2025-01-20 17:27:54.950 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Body><tds:GetSystemDateAndTimeResponse><tds:SystemDateAndTime><tt:DateTimeType>NTP</tt:DateTimeType><tt:DaylightSavings>true</tt:DaylightSavings><tt:TimeZone><tt:TZ>CST+6:00:00DST+6:00:00,M3.2.0/02:00:00,M11.1.0/02:00:00</tt:TZ></tt:TimeZone><tt:UTCDateTime><tt:Time><tt:Hour>23</tt:Hour><tt:Minute>27</tt:Minute><tt:Second>54</tt:Second></tt:Time><tt:Date><tt:Year>2025</tt:Year><tt:Month>1</tt:Month><tt:Day>20</tt:Day></tt:Date></tt:UTCDateTime><tt:LocalDateTime><tt:Time><tt:Hour>17</tt:Hour><tt:Minute>27</tt:Minute><tt:Second>54</tt:Second></tt:Time><tt:Date><tt:Year>2025</tt:Year><tt:Month>1</tt:Month><tt:Day>20</tt:Day></tt:Date></tt:LocalDateTime></tds:SystemDateAndTime></tds:GetSystemDateAndTimeResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:54.950 [DEBUG] [amera.internal.onvif.OnvifConnection] - Camera  UTC dateTime is: 2025-1-20T23:27:54
2025-01-20 17:27:54.951 [DEBUG] [amera.internal.onvif.OnvifConnection] - openHAB UTC dateTime is: 2025-01-20T23:27:54.951Z
2025-01-20 17:27:55.011 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">0v2WF03EfKs9FiGxi8HuwNcJ8lM=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MzY0MTcwNTU1</wsse:Nonce><wsu:Created>2025-01-20T23:27:54.911Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tds:GetCapabilitiesResponse><tds:Capabilities><tt:Device><tt:XAddr>http://192.168.20.52:8000/onvif/device_service</tt:XAddr><tt:Network><tt:IPFilter>false</tt:IPFilter><tt:ZeroConfiguration>false</tt:ZeroConfiguration><tt:IPVersion6>false</tt:IPVersion6><tt:DynDNS>false</tt:DynDNS></tt:Network><tt:System><tt:DiscoveryResolve>true</tt:DiscoveryResolve><tt:DiscoveryBye>true</tt:DiscoveryBye><tt:RemoteDiscovery>false</tt:RemoteDiscovery><tt:SystemBackup>false</tt:SystemBackup><tt:SystemLogging>false</tt:SystemLogging><tt:FirmwareUpgrade>false</tt:FirmwareUpgrade><tt:SupportedVersions><tt:Major>21</tt:Major><tt:Minor>6</tt:Minor></tt:SupportedVersions></tt:System><tt:IO></tt:IO><tt:Security><tt:TLS1.1>false</tt:TLS1.1><tt:TLS1.2>false</tt:TLS1.2><tt:OnboardKeyGeneration>false</tt:OnboardKeyGeneration><tt:AccessPolicyConfig>false</tt:AccessPolicyConfig><tt:X.509Token>false</tt:X.509Token><tt:SAMLToken>false</tt:SAMLToken><tt:KerberosToken>false</tt:KerberosToken><tt:RELToken>false</tt:RELToken></tt:Security></tt:Device><tt:Events><tt:XAddr>http://192.168.20.52:8000/onvif/event_service</tt:XAddr><tt:WSSubscriptionPolicySupport>true</tt:WSSubscriptionPolicySupport><tt:WSPullPointSupport>true</tt:WSPullPointSupport><tt:WSPausableSubscriptionManagerInterfaceSupport>false</tt:WSPausableSubscriptionManagerInterfaceSupport></tt:Events><tt:Imaging><tt:XAddr>http://192.168.20.52:8000/onvif/imaging_service</tt:XAddr></tt:Imaging><tt:Media><tt:XAddr>http://192.168.20.52:8000/onvif/media_service</tt:XAddr><tt:StreamingCapabilities><tt:RTPMulticast>false</tt:RTPMulticast><tt:RTP_TCP>true</tt:RTP_TCP><tt:RTP_RTSP_TCP>true</tt:RTP_RTSP_TCP><tt:Extension></tt:Extension></tt:StreamingCapabilities><tt:Extension><tt:ProfileCapabilities><tt:MaximumNumberOfProfiles>10</tt:MaximumNumberOfProfiles></tt:ProfileCapabilities></tt:Extension></tt:Media><tt:PTZ><tt:XAddr>http://192.168.20.52:8000/onvif/ptz_service</tt:XAddr></tt:PTZ><tt:Extension><tt:DeviceIO><tt:XAddr>http://192.168.20.52:8000/onvif/deviceIO_service</tt:XAddr><tt:VideoSources>1</tt:VideoSources><tt:VideoOutputs>0</tt:VideoOutputs><tt:AudioSources>1</tt:AudioSources><tt:AudioOutputs>0</tt:AudioOutputs><tt:RelayOutputs>0</tt:RelayOutputs></tt:DeviceIO></tt:Extension></tds:Capabilities></tds:GetCapabilitiesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:55.012 [DEBUG] [amera.internal.onvif.OnvifConnection] - deviceXAddr: http://192.168.20.52:8000/onvif/device_service
2025-01-20 17:27:55.012 [DEBUG] [amera.internal.onvif.OnvifConnection] - eventsXAddr: http://192.168.20.52:8000/onvif/event_service
2025-01-20 17:27:55.012 [DEBUG] [amera.internal.onvif.OnvifConnection] - mediaXAddr: http://192.168.20.52:8000/onvif/media_service
2025-01-20 17:27:55.012 [DEBUG] [amera.internal.onvif.OnvifConnection] - ptzXAddr: http://192.168.20.52:8000/onvif/ptz_service
2025-01-20 17:27:55.012 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetProfiles to http://192.168.20.52:8000/onvif/media_service
2025-01-20 17:27:55.648 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">CY4XniZnSB0r0oICoOBb4vHW6LA=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MTM1MTIyMzY5NQ==</wsse:Nonce><wsu:Created>2025-01-20T23:27:55.013Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><trt:GetProfilesResponse><trt:Profiles token="000" fixed="true"><tt:Name>Profile000_MainStream</tt:Name><tt:VideoSourceConfiguration token="000"><tt:Name>VideoS_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken><tt:Bounds x="0" y="0" width="2560" height="1440"></tt:Bounds></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="000"><tt:Name>AudioS_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="000"><tt:Name>VideoE_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>2560</tt:Width><tt:Height>1440</tt:Height></tt:Resolution><tt:Quality>0</tt:Quality><tt:RateControl><tt:FrameRateLimit>15</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>3072</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>30</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>239.0.1.0</tt:IPv4Address></tt:Address><tt:Port>4000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT10S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="000"><tt:Name>AudioE_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:Encoding>AAC</tt:Encoding><tt:Bitrate>16</tt:Bitrate><tt:SampleRate>16</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>238.255.255.255</tt:IPv4Address></tt:Address><tt:Port>25320</tt:Port><tt:TTL>60</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT0S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:VideoAnalyticsConfiguration token="000"><tt:Name>VideoA_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:AnalyticsEngineConfiguration><tt:AnalyticsModule Type="tt:CellMotionEngine" Name="MyCellMotionModule"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="0"></tt:SimpleItem><tt:ElementItem Name="Layout"><tt:CellLayout Columns="80" Rows="45"><tt:Transformation><tt:Translate x="-1.000000" y="-1.000000"/><tt:Scale x="0.000781" y="0.001389"/></tt:Transformation></tt:CellLayout></tt:ElementItem></tt:Parameters></tt:AnalyticsModule></tt:AnalyticsEngineConfiguration><tt:RuleEngineConfiguration><tt:Rule Type="CellMotionDetector" Name="MyMotionDetectorRule"><tt:Parameters><tt:SimpleItem Name="AlarmOnDelay" Value="100"></tt:SimpleItem><tt:SimpleItem Name="AlarmOnDelay" Value="100"></tt:SimpleItem><tt:SimpleItem Name="AlarmOnDelay" Value="Av///PwAAj////wAAw///8D9AAMD///w/AAC///8+wA="></tt:SimpleItem></tt:Parameters></tt:Rule></tt:RuleEngineConfiguration></tt:VideoAnalyticsConfiguration><tt:PTZConfiguration token="000"><tt:Name>PtzConfig000</tt:Name><tt:UseCount>3</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="1" y="1" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace"></tt:PanTilt><tt:Zoom x="1" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace"></tt:Zoom></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration><tt:MetadataConfiguration token="000"><tt:Name>Metadata_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.2.0.0</tt:IPv4Address></tt:Address><tt:Port>40020</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>true</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration></trt:Profiles><trt:Profiles token="001" fixed="true"><tt:Name>Profile001_SubStream</tt:Name><tt:VideoSourceConfiguration token="000"><tt:Name>VideoS_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken><tt:Bounds x="0" y="0" width="2560" height="1440"></tt:Bounds></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="000"><tt:Name>AudioS_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="001"><tt:Name>VideoE_001</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>640</tt:Width><tt:Height>360</tt:Height></tt:Resolution><tt:Quality>2</tt:Quality><tt:RateControl><tt:FrameRateLimit>7</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>160</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>28</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>239.0.1.0</tt:IPv4Address></tt:Address><tt:Port>4000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT10S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="000"><tt:Name>AudioE_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:Encoding>AAC</tt:Encoding><tt:Bitrate>16</tt:Bitrate><tt:SampleRate>16</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>238.255.255.255</tt:IPv4Address></tt:Address><tt:Port>25320</tt:Port><tt:TTL>60</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT0S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:VideoAnalyticsConfiguration token="001"><tt:Name>VideoA_001</tt:Name><tt:UseCount>1</tt:UseCount><tt:AnalyticsEngineConfiguration><tt:AnalyticsModule Type="tt:CellMotionEngine" Name="MyCellMotionModule"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="0"></tt:SimpleItem><tt:ElementItem Name="Layout"><tt:CellLayout Columns="80" Rows="45"><tt:Transformation><tt:Translate x="-1.000000" y="-1.000000"/><tt:Scale x="0.000781" y="0.001389"/></tt:Transformation></tt:CellLayout></tt:ElementItem></tt:Parameters></tt:AnalyticsModule></tt:AnalyticsEngineConfiguration><tt:RuleEngineConfiguration><tt:Rule Type="CellMotionDetector" Name="MyMotionDetectorRule"><tt:Parameters><tt:SimpleItem Name="AlarmOnDelay" Value="100"></tt:SimpleItem><tt:SimpleItem Name="AlarmOnDelay" Value="100"></tt:SimpleItem><tt:SimpleItem Name="AlarmOnDelay" Value="Av///PwAAj////wAAw///8D9AAMD///w/AAC///8+wA="></tt:SimpleItem></tt:Parameters></tt:Rule></tt:RuleEngineConfiguration></tt:VideoAnalyticsConfiguration><tt:PTZConfiguration token="000"><tt:Name>PtzConfig000</tt:Name><tt:UseCount>3</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="1" y="1" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace"></tt:PanTilt><tt:Zoom x="1" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace"></tt:Zoom></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration><tt:MetadataConfiguration token="000"><tt:Name>Metadata_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.2.0.0</tt:IPv4Address></tt:Address><tt:Port>40020</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>true</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration></trt:Profiles></trt:GetProfilesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:55.649 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found: 000
2025-01-20 17:27:55.649 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found: 001
2025-01-20 17:27:55.649 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetSnapshotUri to http://192.168.20.52:8000/onvif/media_service
2025-01-20 17:27:55.650 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetStreamUri to http://192.168.20.52:8000/onvif/media_service
2025-01-20 17:27:55.650 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetNodes to http://192.168.20.52:8000/onvif/ptz_service
2025-01-20 17:27:55.651 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetEventProperties to http://192.168.20.52:8000/onvif/event_service
2025-01-20 17:27:55.651 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetServiceCapabilities to http://192.168.20.52:8000/onvif/event_service
2025-01-20 17:27:55.730 [TRACE] [g.ipcamera.internal.onvif.OnvifCodec] - ONVIF replied with code 400 message is DefaultHttpResponse(decodeResult: success, version: HTTP/1.1)
HTTP/1.1 400 Bad Request
Server: gSOAP/2.8
Content-Type: application/soap+xml; charset=utf-8
Content-Length: 2408
Connection: close
2025-01-20 17:27:55.732 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Body><SOAP-ENV:Fault><SOAP-ENV:Code><SOAP-ENV:Value>SOAP-ENV:Sender</SOAP-ENV:Value></SOAP-ENV:Code><SOAP-ENV:Reason><SOAP-ENV:Text xml:lang="en">Method 'GetServiceCapabilities' not implemented: method name or namespace not recognized</SOAP-ENV:Text></SOAP-ENV:Reason></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:55.733 [TRACE] [amera.internal.onvif.OnvifConnection] - Unhandled ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
2025-01-20 17:27:55.733 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">hC3YqpAoNr7/Xkoc4jhmkmoghF8=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MjAzNTMxOTc4Mg==</wsse:Nonce><wsu:Created>2025-01-20T23:27:55.650Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetNodesResponse><tptz:PTZNode token="000"><tt:Name>Node_000</tt:Name><tt:SupportedPTZSpaces><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:PanTiltSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:PanTiltSpeedSpace></tt:SupportedPTZSpaces><tt:MaximumNumberOfPresets>64</tt:MaximumNumberOfPresets><tt:HomeSupported>false</tt:HomeSupported></tptz:PTZNode></tptz:GetNodesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:55.733 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetStatus to http://192.168.20.52:8000/onvif/ptz_service
2025-01-20 17:27:55.734 [DEBUG] [amera.internal.onvif.OnvifConnection] - ptzNodeToken=000
2025-01-20 17:27:55.734 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetConfigurations to http://192.168.20.52:8000/onvif/ptz_service
2025-01-20 17:27:55.788 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">xhyND9wpQA7/3VqSBNgA8boXoeM=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MTA0MDg4NTU5</wsse:Nonce><wsu:Created>2025-01-20T23:27:55.651Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:GetEventPropertiesResponse><tev:TopicNamespaceLocation>http://www.onvif.org/onvif/ver10/topics/topicns.xml</tev:TopicNamespaceLocation><wsnt:FixedTopicSet>true</wsnt:FixedTopicSet><wstop:TopicSet><tns1:VideoSource wstop:topic="false"><MotionAlarm wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="Source" Type="tt:ReferenceToken"/></tt:Source><tt:Data><tt:SimpleItemDescription Name="State" Type="xsd:boolean"/></tt:Data></tt:MessageDescription></MotionAlarm><ImageTooDark wstop:topic="false"><ImagingService wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="Source" Type="tt:ReferenceToken" /></tt:Source><tt:Data><tt:SimpleItemDescription Name="State" Type="xsd:boolean" /></tt:Data></tt:MessageDescription></ImagingService></ImageTooDark></tns1:VideoSource><tns1:Media wstop:topic="false"><ProfileChanged wstop:topic="true"><tt:MessageDescription IsProperty="false"><tt:Data><tt:SimpleItemDescription Name="Token" Type="tt:ReferenceToken" /></tt:Data></tt:MessageDescription></ProfileChanged><ConfigurationChanged wstop:topic="true"><tt:MessageDescription IsProperty="false"><tt:Source><tt:SimpleItemDescription Name="Token" Type="tt:ReferenceToken" /></tt:Source><tt:Data><tt:SimpleItemDescription Name="Type" Type="xsd:string" /></tt:Data></tt:MessageDescription></ConfigurationChanged></tns1:Media><tns1:RuleEngine wstop:topic="true"><CellMotionDetector wstop:topic="true"><Motion wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="VideoSourceConfigurationToken" Type="tt:ReferenceToken"/><tt:SimpleItemDescription Name="VideoAnalyticsConfigurationToken" Type="tt:ReferenceToken"/><tt:SimpleItemDescription Name="Rule" Type="xsd:string"/></tt:Source><tt:Data><tt:SimpleItemDescription Name="IsMotion" Type="xsd:boolean"/></tt:Data></tt:MessageDescription></Motion></CellMotionDetector></tns1:RuleEngine></wstop:TopicSet><wsnt:TopicExpressionDialect>http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet</wsnt:TopicExpressionDialect><wsnt:TopicExpressionDialect>http://docs.oasis-open.org/wsn/t-1/TopicExpression/Concrete</wsnt:TopicExpressionDialect><tev:MessageContentFilterDialect>http://www.onvif.org/ver10/tev/messageContentFilter/ItemFilter</tev:MessageContentFilterDialect><tev:MessageContentSchemaLocation>http://www.onvif.org/onvif/ver10/schema/onvif.xsd</tev:MessageContentSchemaLocation></tev:GetEventPropertiesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:55.789 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: CreatePullPointSubscription to http://192.168.20.52:8000/onvif/event_service
2025-01-20 17:27:55.912 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">/72qkMuoqHg/p4X7TOHDxszHeg0=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTE0MDg2NzI1MDg=</wsse:Nonce><wsu:Created>2025-01-20T23:27:55.649Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><trt:GetSnapshotUriResponse><trt:MediaUri><tt:Uri>http://192.168.20.52:80/cgi-bin/api.cgi?cmd=onvifSnapPic&amp;channel=0</tt:Uri><tt:InvalidAfterConnect>true</tt:InvalidAfterConnect><tt:InvalidAfterReboot>true</tt:InvalidAfterReboot><tt:Timeout>PT10S</tt:Timeout></trt:MediaUri></trt:GetSnapshotUriResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:55.912 [DEBUG] [amera.internal.onvif.OnvifConnection] - GetSnapshotUri: http://192.168.20.52:80/cgi-bin/api.cgi?cmd=onvifSnapPic&amp;channel=0
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">Xv3FrERtW1V0kzEM22emic0zEMg=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTE0MzcwNzg5NTI=</wsse:Nonce><wsu:Created>2025-01-20T23:27:55.650Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><trt:GetStreamUriResponse><trt:MediaUri><tt:Uri>rtsp://192.168.20.52:554/</tt:Uri><tt:InvalidAfterConnect>false</tt:InvalidAfterConnect><tt:InvalidAfterReboot>false</tt:InvalidAfterReboot><tt:Timeout>PT10S</tt:Timeout></trt:MediaUri></trt:GetStreamUriResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:55.912 [DEBUG] [amera.internal.onvif.OnvifConnection] - GetStreamUri: rtsp://192.168.20.52:554/
2025-01-20 17:27:55.971 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">BkVWv7iOwVdFw7zzUrLlL+HiLH0=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTE5NzEyMjkxODA=</wsse:Nonce><wsu:Created>2025-01-20T23:27:55.733Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetStatusResponse><tptz:PTZStatus><tt:MoveStatus><tt:PanTilt>IDLE</tt:PanTilt><tt:Zoom>IDLE</tt:Zoom></tt:MoveStatus><tt:UtcTime>2025-01-20T23:27:56Z</tt:UtcTime></tptz:PTZStatus></tptz:GetStatusResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:55.971 [DEBUG] [amera.internal.onvif.OnvifConnection] - Processing new PTZ location now
2025-01-20 17:27:55.971 [WARN ] [amera.internal.onvif.OnvifConnection] - Binding could not determin the cameras current PTZ location. Not all cameras respond to GetStatus requests.
2025-01-20 17:27:56.011 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.20.52:8000/onvif/event_service</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">+jXoa8cvjR+gG9f0GwEwS1nw0CM=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTcyMDEwNTg5NA==</wsse:Nonce><wsu:Created>2025-01-20T23:27:55.790Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:CreatePullPointSubscriptionResponse><tev:SubscriptionReference><wsa5:Address>http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615</wsa5:Address></tev:SubscriptionReference><wsnt:CurrentTime>2025-01-20T23:27:56Z</wsnt:CurrentTime><wsnt:TerminationTime>2025-01-20T23:37:56Z</wsnt:TerminationTime></tev:CreatePullPointSubscriptionResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.012 [DEBUG] [amera.internal.onvif.OnvifConnection] - subscriptionXAddr=http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
2025-01-20 17:27:56.012 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: PullMessages to http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
2025-01-20 17:27:56.012 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">kV2WTK5M90uv55uTmOI2aTxPl2c=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTI5NTIwNDM2MQ==</wsse:Nonce><wsu:Created>2025-01-20T23:27:55.734Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetConfigurationsResponse><tptz:PTZConfiguration token="000"><tt:Name>PtzConfig000</tt:Name><tt:UseCount>3</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="1" y="1" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace"></tt:PanTilt><tt:Zoom x="1" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace"></tt:Zoom></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tptz:PTZConfiguration></tptz:GetConfigurationsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.013 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetPresets to http://192.168.20.52:8000/onvif/ptz_service
2025-01-20 17:27:56.013 [DEBUG] [amera.internal.onvif.OnvifConnection] - ptzConfigToken=000
2025-01-20 17:27:56.013 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetConfigurationOptions to http://192.168.20.52:8000/onvif/ptz_service
2025-01-20 17:27:56.092 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">WlnRNwUAJ1PB3Vvwv09AVUOsPHM=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTE5NTMyMTIxNzM=</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.013Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetPresetsResponse></tptz:GetPresetsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.115 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">S9C3sENBBP8HyIeLrO3R4554+ew=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTE0MzczMDY5Mzk=</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.014Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetConfigurationOptionsResponse><tptz:PTZConfigurationOptions><tt:Spaces><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:PanTiltSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:PanTiltSpeedSpace></tt:Spaces><tt:PTZTimeout><tt:Min>PT1S</tt:Min><tt:Max>PT10S</tt:Max></tt:PTZTimeout></tptz:PTZConfigurationOptions></tptz:GetConfigurationOptionsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.116 [TRACE] [amera.internal.onvif.OnvifConnection] - Unhandled ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
2025-01-20 17:27:56.143 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">s0R+eVXD7STeQxDgzIKtHSr8pm8=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MTEyMjU2NDMxOA==</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.012Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2025-01-20T23:27:56Z</tev:CurrentTime><tev:TerminationTime>2025-01-20T23:37:56Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2025-01-20T23:27:56Z" PropertyOperation="Initialized"><tt:Source><tt:SimpleItem Name="VideoSourceConfigurationToken" Value="000" /><tt:SimpleItem Name="VideoAnalyticsConfigurationToken" Value="000" /><tt:SimpleItem Name="Rule" Value="000" /></tt:Source><tt:Data><tt:SimpleItem Name="IsMotion" Value="false" /></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.143 [DEBUG] [amera.internal.onvif.OnvifConnection] - ONVIF Event Topic: RuleEngine/CellMotionDetector/Motion, Data: IsMotion, Value: false
2025-01-20 17:27:56.143 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: PullMessages to http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
2025-01-20 17:27:56.198 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">Cfyn3viLUAnWUmON9ZH7g5OIrUs=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MTQ4NTc0MTY5MQ==</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.144Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2025-01-20T23:27:56Z</tev:CurrentTime><tev:TerminationTime>2025-01-20T23:37:56Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/MyRuleDetector/FaceDetect</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2025-01-20T23:27:56Z" PropertyOperation="Initialized"><tt:Source><tt:SimpleItem Name="Source" Value="VideoSourceToken" /></tt:Source><tt:Data><tt:SimpleItem Name="State" Value="false" /></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.199 [DEBUG] [amera.internal.onvif.OnvifConnection] - ONVIF Event Topic: RuleEngine/MyRuleDetector/FaceDetect, Data: State, Value: false
2025-01-20 17:27:56.199 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: PullMessages to http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
2025-01-20 17:27:56.246 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">mx0Vo5JOzxCdAv6d/T8mu4RCHbE=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MTY0MjU3MDM2Mw==</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.199Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2025-01-20T23:27:56Z</tev:CurrentTime><tev:TerminationTime>2025-01-20T23:37:56Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/MyRuleDetector/PeopleDetect</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2025-01-20T23:27:56Z" PropertyOperation="Initialized"><tt:Source><tt:SimpleItem Name="Source" Value="VideoSourceToken" /></tt:Source><tt:Data><tt:SimpleItem Name="State" Value="false" /></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.247 [DEBUG] [amera.internal.onvif.OnvifConnection] - ONVIF Event Topic: RuleEngine/MyRuleDetector/PeopleDetect, Data: State, Value: false
2025-01-20 17:27:56.247 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: PullMessages to http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
2025-01-20 17:27:56.288 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">a6m00+qyWEStgCW5yJaO1Wxm2oU=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTE2MDM5NTg4ODY=</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.247Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2025-01-20T23:27:56Z</tev:CurrentTime><tev:TerminationTime>2025-01-20T23:37:56Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/MyRuleDetector/VehicleDetect</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2025-01-20T23:27:56Z" PropertyOperation="Initialized"><tt:Source><tt:SimpleItem Name="Source" Value="VideoSourceToken" /></tt:Source><tt:Data><tt:SimpleItem Name="State" Value="false" /></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.288 [DEBUG] [amera.internal.onvif.OnvifConnection] - ONVIF Event Topic: RuleEngine/MyRuleDetector/VehicleDetect, Data: State, Value: false
2025-01-20 17:27:56.288 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: PullMessages to http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
2025-01-20 17:27:56.348 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">tkOh4eeuMl3jg7Rgaz9f/UWpkfo=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTEzODc4MDU4ODg=</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.288Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2025-01-20T23:27:56Z</tev:CurrentTime><tev:TerminationTime>2025-01-20T23:37:56Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/MyRuleDetector/DogCatDetect</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2025-01-20T23:27:56Z" PropertyOperation="Initialized"><tt:Source><tt:SimpleItem Name="Source" Value="VideoSourceToken" /></tt:Source><tt:Data><tt:SimpleItem Name="State" Value="false" /></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.348 [DEBUG] [amera.internal.onvif.OnvifConnection] - ONVIF Event Topic: RuleEngine/MyRuleDetector/DogCatDetect, Data: State, Value: false
2025-01-20 17:27:56.348 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: PullMessages to http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
2025-01-20 17:27:56.387 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">kNAK43CRhFewXL3g4RxnnuW5MQM=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">OTQyODQ5ODY4</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.348Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2025-01-20T23:27:56Z</tev:CurrentTime><tev:TerminationTime>2025-01-20T23:37:56Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:VideoSource/MotionAlarm</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2025-01-20T23:27:56Z" PropertyOperation="Initialized"><tt:Source><tt:SimpleItem Name="Source" Value="000" /></tt:Source><tt:Data><tt:SimpleItem Name="State" Value="false" /></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:27:56.387 [DEBUG] [amera.internal.onvif.OnvifConnection] - ONVIF Event Topic: VideoSource/MotionAlarm, Data: State, Value: false
2025-01-20 17:27:56.387 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: PullMessages to http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
2025-01-20 17:27:58.912 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.20.52:80/cgi-bin/api.cgi?cmd=onvifSnapPic&amp;channel=0
2025-01-20 17:28:04.615 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">+VF5a4wL/5c0bQICATO57PiRKd0=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MzAwMDc5ODEx</wsse:Nonce><wsu:Created>2025-01-20T23:27:56.388Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2025-01-20T23:27:56Z</tev:CurrentTime><tev:TerminationTime>2025-01-20T23:37:56Z</tev:TerminationTime></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2025-01-20 17:28:04.616 [DEBUG] [amera.internal.onvif.OnvifConnection] - No ONVIF Events occured in the last 8 seconds
2025-01-20 17:28:04.616 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: PullMessages to http://192.168.20.52:8000/onvif/PullSubManager?Idx=142061615
By looking at the log we can find one error.
2025-01-20 17:27:55.651 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetServiceCapabilities to http://192.168.20.52:8000/onvif/event_service
2025-01-20 17:27:55.730 [TRACE] [g.ipcamera.internal.onvif.OnvifCodec] - ONVIF replied with code 400 message is DefaultHttpResponse(decodeResult: success, version: HTTP/1.1)
HTTP/1.1 400 Bad Request
Server: gSOAP/2.8
Content-Type: application/soap+xml; charset=utf-8
Content-Length: 2408
Connection: close
The associated error message in the camera XML response to that request says:
Method ‘GetServiceCapabilities’ not implemented: method name or namespace not recognized
I don’t know the inner working of the IPCamera binding but If the error you get in the Thing configuration is not related with this error then I have no idea of what it may be.
I think @matt1 can help here :wink:
The log looks like it is working fine to me, unless you have the other camera still enabled and the logs are from a different camera? If so use the pause button on the thing to prevent it muddying up the logs. Some cameras do not fully implement ONVIF so you do get some replies back with a 400 code.
Try a different firmware from the link to github here and also upgrade to the latest openHAB as a lot of changes were made to help Reolink in the last few builds.
