Trying to update zulu everytime
Running openhabian 2.5@Rpi3 and everytime i update via openhab-config it keeps re/updating zulu java too. I get :
2019-12-28_17:53:29_EET [openHABian] Updating repositories and upgrading installed packages...
$ wget -O openhab-key.asc https://bintray.com/user/downloadSubjectPublicKey?username=openhab
--2019-12-28 17:53:29--  https://bintray.com/user/downloadSubjectPublicKey?username=openhab
Resolving bintray.com (bintray.com)... 75.126.208.206
Connecting to bintray.com (bintray.com)|75.126.208.206|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: ā€˜openhab-key.asc’
openhab-key.asc                                     [ <=>        ]   3.14K  --.-KB/s    in 0.001s
2019-12-28 17:53:30 (3.57 MB/s) - ā€˜openhab-key.asc’ saved [3219]
$ apt-key add openhab-key.asc
OK
$ apt-get --yes upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ java_install_or_update
openjdk version "1.8.0_222"
OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222-b178)
OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation)
$ systemctl stop openhab2.service
2019-12-28_17:54:11_EET [openHABian] Installing Java Zulu 32-Bit OpenJDK...
$ wget -nv -O /tmp/openhabian.IPFRd/zulu8.tar.gz https://cdn.azul.com/zulu-embedded/bin/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf.tar.gz
2019-12-28 17:55:03 URL:https://cdn.azul.com/zulu-embedded/bin/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf.tar.gz [175560479/175560479] -> "/tmp/openhabian.IPFRd/zulu8.tar.gz" [1]
$ update-alternatives --remove-all java
$ update-alternatives --remove-all javac
$ update-alternatives --install /usr/bin/java java /opt/jdk/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf/bin/java 1083000
update-alternatives: using /opt/jdk/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf/bin/java to provide /usr/bin/java (java) in auto mode
$ update-alternatives --install /usr/bin/javac javac /opt/jdk/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf/bin/javac 1083000
update-alternatives: using /opt/jdk/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf/bin/javac to provide /usr/bin/javac (javac) in auto mode
$ wget -nv -O /tmp/openhabian.bhrxP/crypto.zip http://cdn.azul.com/zcek/bin/ZuluJCEPolicies.zip
2019-12-28 17:56:20 URL:http://cdn.azul.com/zcek/bin/ZuluJCEPolicies.zip [12181/12181] -> "/tmp/openhabian.bhrxP/crypto.zip" [1]
$ unzip /tmp/openhabian.bhrxP/crypto.zip -d /tmp/openhabian.bhrxP
Archive:  /tmp/openhabian.bhrxP/crypto.zip
   creating: /tmp/openhabian.bhrxP/ZuluJCEPolicies/
  inflating: /tmp/openhabian.bhrxP/ZuluJCEPolicies/LICENSE
  inflating: /tmp/openhabian.bhrxP/ZuluJCEPolicies/README.txt
  inflating: /tmp/openhabian.bhrxP/ZuluJCEPolicies/DISCLAIMER
  inflating: /tmp/openhabian.bhrxP/ZuluJCEPolicies/local_policy.jar
  inflating: /tmp/openhabian.bhrxP/ZuluJCEPolicies/US_export_policy.jar
OK
Is that normal???
Have you ran this from command line?
wget -qO - 'https://bintray.com/user/downloadSubjectPublicKey?username=openhab' | sudo apt-key add -
ok thnx mate
Did you copy and paste or type it in? I ask b/c I think it’s a capital O behind the -q
You also missed the first line of the command. It is wget not get
What am I missing?
yes i got it ,its updated ok but still it tries to update java again stoping openhab.service and restarting…
Yes its normal for openhabian to update and usually mentions that it’s the latest version. It also checks most everything else as well.
Are you having an issue or just curious about the message?
i dont have an issue other than it restarts openhab.service everytime i check for updates…i was just more curious about it.
When you use openhabian-config to update it stops OH, updates, and restarts everything so it’s normal.:smiley:
Same here. As reported below each time I upgrade system in openhabian-config it seems to install java again. It started to do this some months ago with Openhab 2.4
I did a upgrade to Openhab 2.5 and it’s still the same.
I didn’t understand… is it normal?
2020-01-04_14:34:06_CET [openHABian] Installing Java Zulu 32-Bit OpenJDK...
$ wget -nv -O /tmp/openhabian.RGLTQ/zulu8.tar.gz https://cdn.azul.com/zulu-embedded/bin/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf.tar.gz
2020-01-04 14:34:34 URL:https://cdn.azul.com/zulu-embedded/bin/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf.tar.gz [175560479/175560479] -> "/tmp/openhabian.RGLTQ/zulu8.tar.gz" [1]
$ wget -nv -O /tmp/openhabian.AX6Gl/crypto.zip http://cdn.azul.com/zcek/bin/ZuluJCEPolicies.zip
2020-01-04 14:34:59 URL:http://cdn.azul.com/zcek/bin/ZuluJCEPolicies.zip [12181/12181] -> "/tmp/openhabian.AX6Gl/crypto.zip" [1]
$ unzip /tmp/openhabian.AX6Gl/crypto.zip -d /tmp/openhabian.AX6Gl
Archive:  /tmp/openhabian.AX6Gl/crypto.zip
   creating: /tmp/openhabian.AX6Gl/ZuluJCEPolicies/
  inflating: /tmp/openhabian.AX6Gl/ZuluJCEPolicies/LICENSE
  inflating: /tmp/openhabian.AX6Gl/ZuluJCEPolicies/README.txt
  inflating: /tmp/openhabian.AX6Gl/ZuluJCEPolicies/DISCLAIMER
  inflating: /tmp/openhabian.AX6Gl/ZuluJCEPolicies/local_policy.jar
  inflating: /tmp/openhabian.AX6Gl/ZuluJCEPolicies/US_export_policy.jar
OK
$ systemctl start openhab2.service
OK
I think it is normal. @mstormi can verify.
Normal yes, optimal no.
Add a ā€œme tooā€ to https://github.com/openhab/openhabian/issues/723
