Hi Flip,
Config.json below:
“host”: “192.68.0.107”,
“port”: 1883,
“topic”: “tuya/switch”,
“mqtt_user”: “”,
“mqtt_pass”: “”
Debug results:
openhabian@openhabian:/opt/tuya-mqtt $ DEBUG=* node tuya-mqtt.js
mqttjs connecting to an MQTT broker… +0ms
mqttjs:client MqttClient :: options.protocol mqtt +0ms
mqttjs:client MqttClient :: options.protocolVersion 4 +0ms
mqttjs:client MqttClient :: options.username +3ms
mqttjs:client MqttClient :: options.keepalive 60 +0ms
mqttjs:client MqttClient :: options.reconnectPeriod 1000 +1ms
mqttjs:client MqttClient :: options.rejectUnauthorized undefined +0ms
mqttjs:client MqttClient :: options.topicAliasMaximum undefined +0ms
mqttjs:client MqttClient :: clientId mqttjs_0bc98302 +1ms
mqttjs:client MqttClient :: setting up stream +1ms
mqtt-packet:parser _resetState: resetting packet, error, _list, and _stateCounter +0ms
mqttjs:client _setupStream :: calling method to clear reconnect +6ms
mqttjs:client _clearReconnect : clearing reconnect timer +1ms
mqttjs:client _setupStream :: using streamBuilder provided to client to create stream +0ms
mqttjs calling streambuilder for mqtt +22ms
mqttjs:tcp port 1883 and host 192.68.0.107 +0ms
mqttjs:client _setupStream :: pipe stream to writable stream +5ms
mqttjs:client _setupStream: sending packet connect
+4ms
mqttjs:client sendPacket :: packet: { cmd: ‘connect’ } +1ms
mqttjs:client sendPacket :: emitting packetsend
+7ms
mqttjs:client sendPacket :: writing to stream +0ms
mqtt-packet:writeToStream generate called +0ms
mqtt-packet:writeToStream generate: packet.cmd: connect +164ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 1f> +4ms
mqtt-packet:writeToStream writeNumberCached: number: 4 +3ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 04> +1ms
mqtt-packet:writeToStream writeString: MQTT +1ms
mqtt-packet:writeToStream writeNumberCached: number: 60 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 3c> +1ms
mqtt-packet:writeToStream writeNumberCached: number: 15 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 0f> +0ms
mqtt-packet:writeToStream writeString: mqttjs_0bc98302 +1ms
mqtt-packet:writeToStream writeNumberCached: number: 0 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 00> +0ms
mqtt-packet:writeToStream writeString: +1ms
mqttjs:client sendPacket :: writeToStream result true +182ms
mqttjs:client !!connectTimeout hit!! Calling _cleanUp with force true
+30s
mqttjs:client _cleanUp :: forced? true +3ms
mqttjs:client _cleanUp :: (mqttjs_0bc98302) :: destroying stream +2ms
mqttjs:client _cleanUp :: client not disconnecting. Clearing and resetting reconnect. +4ms
mqttjs:client _setupReconnect :: emit offline
state +1ms
mqttjs:client _setupReconnect :: set reconnecting
to true
+1ms
mqttjs:client _setupReconnect :: setting reconnectTimer for 1000 ms +1ms
mqttjs:client (mqttjs_0bc98302)stream :: on close +4ms
mqttjs:client flushVolatile :: deleting volatile messages from the queue and setting their callbacks as error function +2ms
mqttjs:client stream: emit close to MqttClient +0ms
mqttjs:client close :: connected set to false
+1ms
mqttjs:client close :: clearing connackTimer +0ms
mqttjs:client close :: clearing ping timer +1ms
mqttjs:client close :: calling _setupReconnect +0ms
mqttjs:client _setupReconnect :: doing nothing… +1ms
mqttjs:client reconnectTimer :: reconnect triggered! +994ms
mqttjs:client _reconnect: emitting reconnect to client +1ms
tuya-mqtt:info Unable to connect to MQTT server +0ms
mqttjs:client _reconnect: calling _setupStream +1ms
mqtt-packet:parser _resetState: resetting packet, error, _list, and _stateCounter +31s
mqttjs:client _setupStream :: calling method to clear reconnect +2ms
mqttjs:client _setupStream :: using streamBuilder provided to client to create stream +1ms
mqttjs calling streambuilder for mqtt +31s
mqttjs:tcp port 1883 and host 192.68.0.107 +31s
mqttjs:client _setupStream :: pipe stream to writable stream +4ms
+1ms
+1ms
mqttjs:client sendPacket :: writing to stream +1ms
mqtt-packet:writeToStream generate called +31s
mqtt-packet:writeToStream generate: packet.cmd: connect +1ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 1f> +1ms
mqtt-packet:writeToStream writeNumberCached: number: 4 +1ms
mqtt-packet:writeToStream writeNumberCached: number: 0 +0ms
mqttjs:client sendPacket :: writeToStream result true +11ms
+30s
mqttjs:client _cleanUp :: forced? true +1ms
mqttjs:client _cleanUp :: (mqttjs_0bc98302) :: destroying stream +0ms
mqttjs:client _cleanUp :: client not disconnecting. Clearing and resetting reconnect. +1ms
mqttjs:client _clearReconnect : clearing reconnect timer +0ms
mqttjs:client (mqttjs_0bc98302)stream :: on close +1ms
mqttjs:client flushVolatile :: deleting volatile messages from the queue and setting their callbacks as error function +1ms
+1ms
mqttjs:client _setupReconnect :: doing nothing… +0ms
mqttjs:client reconnectTimer :: reconnect triggered! +997ms
tuya-mqtt:info Unable to connect to MQTT server +31s
mqttjs:client _setupStream :: calling method to clear reconnect +1ms
mqttjs:client _setupStream :: pipe stream to writable stream +2ms
+1ms
+1ms
mqtt-packet:writeToStream generate: packet.cmd: connect +0ms
mqtt-packet:writeToStream writeString: MQTT +0ms
mqtt-packet:writeToStream writeNumberCached: number: 60 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 3c> +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 00> +1ms
mqtt-packet:writeToStream writeString: +0ms
+30s
mqttjs:client _setupReconnect :: setting reconnectTimer for 1000 ms +0ms
mqttjs:client stream: emit close to MqttClient +10ms
+1ms
mqttjs:client close :: clearing ping timer +0ms
mqttjs:client close :: calling _setupReconnect +1ms
mqttjs:client reconnectTimer :: reconnect triggered! +989ms
mqttjs:client _reconnect: calling _setupStream +0ms
mqttjs:client _setupStream :: pipe stream to writable stream +1ms
+1ms
+1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 04> +0ms
mqtt-packet:writeToStream writeNumberCached: number: 15 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 0f> +1ms
mqtt-packet:writeToStream writeString: mqttjs_0bc98302 +0ms
mqttjs:client sendPacket :: writeToStream result true +8ms
+30s
mqttjs:client _cleanUp :: forced? true +0ms
mqttjs:client _cleanUp :: (mqttjs_0bc98302) :: destroying stream +1ms
mqttjs:client _cleanUp :: client not disconnecting. Clearing and resetting reconnect. +0ms
mqttjs:client flushVolatile :: deleting volatile messages from the queue and setting their callbacks as error function +0ms
+0ms
mqttjs:client reconnectTimer :: reconnect triggered! +999ms
+1ms
mqttjs:client sendPacket :: packet: { cmd: ‘connect’ } +0ms
+0ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 1f> +0ms
mqttjs:client sendPacket :: writeToStream result true +6ms
+30s
+0ms
mqttjs:client close :: clearing connackTimer +1ms
mqttjs:client reconnectTimer :: reconnect triggered! +1s
+1ms
+1ms
mqtt-packet:writeToStream writeNumberCached: number: 4 +0ms
mqttjs:client sendPacket :: writeToStream result true +7ms
+30s
+1ms
mqttjs:client _reconnect: emitting reconnect to client +0ms
mqttjs:client _setupStream :: calling method to clear reconnect +0ms
+0ms
+1ms
+30s
mqttjs:client (mqttjs_0bc98302)stream :: on close +0ms
+0ms
+0ms
+1ms
+30s
+1ms
+0ms
+3ms
+30s
mqttjs:client stream: emit close to MqttClient +1ms
+0ms
+1ms
+1ms
+30s
+0ms
+1ms
+1ms
+30s
+0ms
mqttjs:client reconnectTimer :: reconnect triggered! +998ms
+0ms
+0ms
+30s
+0ms
+1ms
+0ms
+30s
+1ms
+1ms
+1ms
+30s
+0ms
+1ms
+1ms
Not sure if any of this helps, thanks again for your help.
George
