I have in my installation TZ35S single pad dimmer from TKB. On my list it displays as TZ65D. I have xml file for it. @chris if you could grant me rights to edit database I would try to update it. In meantime I am attaching xml from my system.
Do you mean you were pasting anXML into a message on the forum? If so, you need to format it with code fences (eg ``` before and after the xml will probably do).
No, I used create device from on your website and pasted xml into the note edit box. As a result I received error: “1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘39,1,1,1629)’ at line 3”
I’m having this issue and still very new to OpenHAB, my device is a TZ65D but being displayed as a TZ35S. I only have The TZ65D installed in the house, anyway so i can switch it?
