Unable to add things
  • Platform information:
    • Hardware: arm71/4GB/32GB
    • OS: Linux/5.10.103-v7l+ (arm)
    • Java Runtime Environment: 11.0.14 (undefined)
    • openHAB version: 3.2.0 - Release Build
  • Issue of the topic: Cannot add any ‘Things’.
    I currently have installed just a few bindings for testing purposes:
    • ntp
    • onewire
    • weatherunderground
      The main goal was to get onewire working. As of now I got owserver perfectly working and showing the information it have read from connected 18B20 sensors. That means owserver and owhttpd are accessible through their respective default ports.
      Any further steps failed. No matter how many times I tried adding the Thing (for owserver as Bridge Thing, for any sensors as Things), nothing happens - after completing the Thing addition form, I am simply put back into empty Things screen which says there are No Things.
      As a sidestep I tried adding the NTP thing from Inbox which showed up there after I added NTP binding. This also failed, saying - there is a Server Error.
      Overall the first impressions are - this is a very “green” product, where nothing works, even if it’s a ‘Release’ edition.
      Please disperse my doubts, and tell me what I’m doing wrong.
      P.S. This is already my second attempt, because I got messed a lot up by trials and errors on my first try while getting the owserver to work properly. I thought then the Things problem could be linked to that, but no, this is a separate issue.
Can you maybe share some logging from the logfiles?
I think that you will find some explanation in there what the error could be.
Otherwise I would suggest to clear the OpenHAB cache and restart it.
See: Clear the Cache
If that all fails, you can also try to add things via things files instead of via the MainUI.
See: Things | openHAB
Hope this helps!
  • Jordo
I guess, this is what is being repeated gazillion times in the openhab.log
I apologize, I’m a total newcomer here with a very limited experience in Linux domain, thus I’m not very proficient in solving any problems there.
2022-03-17 09:56:13.054 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Application {http://internal.id.core.openhab.org/}UUIDResource has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Could not initialize class org.openhab.binding.onewire.internal.OwBindingConstants
at org.apache.cxf.service.invoker.AbstractInvoker.createFault(AbstractInvoker.java:162) ~[bundleFile:3.4.5]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:128) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:217) ~[bundleFile:3.4.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.openhab.binding.onewire.internal.OwBindingConstants
at org.openhab.binding.onewire.internal.OwHandlerFactory.supportsThingType(OwHandlerFactory.java:61) ~[?:?]
at org.openhab.core.thing.binding.ThingFactory.createThing(ThingFactory.java:100) ~[?:?]
at org.openhab.core.config.discovery.internal.PersistentInbox.approve(PersistentInbox.java:206) ~[?:?]
at org.openhab.core.io.rest.core.internal.discovery.InboxResource.approve(InboxResource.java:120) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[bundleFile:3.4.5]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[bundleFile:3.4.5]
… 50 more
2022-03-17 09:56:13.085 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Exception in handleFault on interceptor org.apache.cxf.jaxrs.interceptor.JAXRSDefaultFaultOutInterceptor@55fd28
… 50 more
2022-03-17 09:56:13.111 [ERROR] [.AbstractFaultChainInitiatorObserver] - An unexpected error occurred during error handling. No further error processing will occur.
… 50 more
2022-03-17 09:56:13.136 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/inbox/ntp:ntp:local/approve
at org.apache.cxf.service.invoker.AbstractInvoker.createFault(AbstractInvoker.java:162) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:128) ~[?:?]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[?:?]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[?:?]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[?:?]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[?:?]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[?:?]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[?:?]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[?:?]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[?:?]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[?:?]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[?:?]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[?:?]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[?:?]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:217) ~[?:?]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[?:?]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) ~[bundleFile:9.4.43.v20210629]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[?:?]
… 50 more
Found that one culprit string, then changed the language back to English, an miraculously everything began working.
P.S. Latvian language is not completely implemented…
I assume the problem is solved then, at least for now?
Affirmative. This problem is gone for now. However the learning process is far from straightforward. Too less information available, too unrelated to OH3. A lot of broken links here and there, where useful manuals and help information should be.
Update.
On my second fresh installation attempt I found (as I assumed) “how things must be done” (OneWire begun working, Grafana instlled and working). Howerver some issues still had to be addressed - I got the main admin user missing somehow, and after I recreated it from the console, the OneWire server went haywired, dropping out entire hours of data. Thus, assuming “I know it all” I proceeded to 3rd fresh install.
This time I went completely lean - no fancy regional settings, no unnecesary bindings. Everything stock, as coming from distributive image. (The only thing coming from “outside world” was the OWSERVER itself - I installed it via APT-GET, as on the 2nd attempt, because I hadn’t yet found it was bundled and installable via Optional Components.)
Boom… The same error as on previous installation - the OW thing is not added, the log shows the same debug information.
I tried changing regional settings back and forth, uninstalling and reinstalling the OW binding, restarting both OH an OW services and entire Rasp, to no avail.
Then I went for the 4th time fresh install. Again, not touching regional settings on 1st startup and leaving them as default en_US. This time I installed OW server from Optional Components. No way. It is not working either.
Thus I assume there definitely something wrong went unchecked into the release.
Yet some more clues - on the 2nd attempt, I observed the updates were being offered for Openhabian, and then I got them installed via apt-get update / upgrade at some point. This time there are no updates offered even if check for them either from apt-get or openhabian-config.
