I can’t see anywhere that the procedure has changed. Karaf appears to be updating the file and replacing the clear-text password with the hashed one.. And the crypt matches the password ‘SecurePassword’
Err… but you didn’t kill the rest of this file, did you? The complete file users.properties should be
# Licensed to the Apache Software Foundation (ASF) under one or more
# contributor license agreements. See the NOTICE file distributed with
# this work for additional information regarding copyright ownership.
# The ASF licenses this file to You under the Apache License, Version 2.0
# (the "License"); you may not use this file except in compliance with
# the License. You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# This file contains the users, groups, and roles.
# Each line has to be of the format:
# USER=PASSWORD,ROLE1,ROLE2,...
# USER=PASSWORD,_g_:GROUP,...
# _g_\:GROUP=ROLE1,ROLE2,...
# All users, groups, and roles entered in this file are available after Karaf startup
# and modifiable via the JAAS command group. These users reside in a JAAS domain
# with the name "karaf".
openhab = {CRYPT}78635493C01FAD877DAE26F1CE681CFAFABE0C9F27950D1EDE6C9D55B616A5D2CRYPT},_g_:admingroup
_g_\:admingroup = group,admin,manager,viewer,systembundles
where openHAB itself will encrypt the password when it was changed to another (not yet encrypted) password.
Originally there was no users.properties file (I think that was when I was using 2.1.0-2). I simply added the file with the entry documented in the openHab docs.
Note that with 2.1.0-1 it was working with just
openhab = {CRYPT}shar256sum{CRYPT}
I haven’t needed console since then, until trying to debug all the issues I have with 2.2.0-1…
Thanks @Udo_Hartmann. That second line did the trick.
I don’t know what part of the system should have been responsible for creating the users.properties, but perhaps the rest of it could be documented somewhere?
