I am running openHAB 4.1.1.
I am not able to add a Linear Corp switch.
It throws the following error when i try to add it: “Thing zwave:device:ctrlr:nodexx unable to be approved: Duplicate channels zwave:device:ctrlr:node41:scene_number”
Can this be fixed?
The xml data:
<node>
<homeId>0x xxxx</homeId>
<nodeId>xx</nodeId>
<version>4</version>
<manufacturer>0x14f</manufacturer>
<deviceId>0x3535</deviceId>
<deviceType>0x5753</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_CENTRAL_SCENE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_ALL</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTIVATION</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTUATOR_CONF</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map"/>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_POWER_SWITCH_BINARY</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__BINARY>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__ALL>
<mode>SWITCH_ALL_EXCLUDED</mode>
</COMMAND__CLASS__SWITCH__ALL>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTIVATION>
</COMMAND__CLASS__SCENE__ACTIVATION>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTUATOR__CONF>
</COMMAND__CLASS__SCENE__ACTUATOR__CONF>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__CENTRAL__SCENE>
<sceneCount>0</sceneCount>
</COMMAND__CLASS__CENTRAL__SCENE>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>0</zwPlusVersion>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL</commandClass>
<COMMAND__CLASS__MULTI__CHANNEL>
<useDestEndpointAsSource>false</useDestEndpointAsSource>
<endpointsAreTheSameDeviceClass>false</endpointsAreTheSameDeviceClass>
</COMMAND__CLASS__MULTI__CHANNEL>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters>
<entry>
<int>3</int>
<configurationParameter>
<index>3</index>
<size>1</size>
<value>1</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>1</size>
<value>0</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>335</deviceManufacturer>
<deviceType>21079</deviceType>
<deviceId>13619</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>6</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>0</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ROUTING</libraryType>
<protocolVersion>3.42</protocolVersion>
<applicationVersion>5.41</applicationVersion>
</COMMAND__CLASS__VERSION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>2</int>
<int>3</int>
<int>5</int>
<int>6</int>
<int>7</int>
<int>8</int>
<int>9</int>
<int>10</int>
<int>11</int>
<int>12</int>
<int>13</int>
<int>14</int>
<int>15</int>
<int>16</int>
<int>17</int>
<int>19</int>
<int>20</int>
<int>21</int>
<int>22</int>
<int>23</int>
<int>24</int>
<int>25</int>
<int>26</int>
<int>27</int>
<int>28</int>
<int>29</int>
<int>30</int>
<int>31</int>
<int>33</int>
<int>34</int>
<int>35</int>
<int>36</int>
</nodeNeighbors>
<lastReceived>2024-01-30 19:59:14.227 UTC</lastReceived>
</node>
